Home > Maintenance & Modifications > Steering upgrade to Disco version
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Hi. I have a perished rubber on my drag link at the steering box end on my 2013 puma 110. I though it might be sensible to upgrade the components to the disco version I have heard about but don't know exactly what this entails.
Could somebody please point me on the right direction? V8 90...WIP
Post #686690 15th Feb 2018 8:40am
bankz5152
Gywn Lewis do a full kit inc HD steering bars. Job isnt to hard to do, takes a little time to adjust tho. Be sure to have an angle grinder and some cold chisles handy just incase the actual drop arm wont come off. Mine didnt! Be careful if you do cut not to damage the splines.
Well worth while upgrade, much "tighter" steering.
Post #686693 15th Feb 2018 8:54am
jst
I do this upgrade to track rod end instead of drop arm ball joint to all my defenders when the ball joint first needs replacing. Makes future maint so much easier. You can use std disco drag link, you ring hedge to use the gywn Lewis one. Having said that I do. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686694 15th Feb 2018 9:01am
Paulv8
Ring hedge? Lol. V8 90...WIP
Post #686695 15th Feb 2018 9:03am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've done the same on the 90 and very happy with it. Never liked the drop arm ball joint, it's a PITA to change and one less part to keep as spares. I had a disco drop arm in the shed so purchased the longer drag link and damper bracket from Gwyn then a couple of new TREs, there are instructions on his website about setting it up. I'll be doing the same to the 110 soon. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #686728 15th Feb 2018 11:13am
jst
Paulv8 wrote:
Ring hedge? Lol.
Sorry 'don't have to' Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686852 15th Feb 2018 9:25pm
JOW240725
This thread might be of interest. It's on my list... Whistle
http://www.defender2.net/forum/topic56286.html James
Instagram @suffolk_rovers
Post #686865 15th Feb 2018 10:02pm
UtilityTruck
I can see the benefit of stiffer track+drag bars, but how does the attachment method of the damper to the link make a difference? Not trolling- I just cannot see what difference this part would make? Is anyone running uprated bars with the standard steering box arm?
Edit; the disco arm looks a little more robust and ‘chunkier’, perhaps a factor? 2014 Keswick Utility 2.2
Post #686871 15th Feb 2018 10:26pm
Lotus_esprit_s1
All three of my defenders have HD steering arms on the standard drop arm set up. With the correct installation and removal tools including the press to hold the joint together when fitting the circlip the ball joint is a doddle to change.
I swapped to the Hd steering arms when I noticed some play in the threads of the drag link balljoint despite the clamp being tight; they just seem so much more substantial.
Post #686904 16th Feb 2018 1:32am
