![]() | Home > Technical > No ignition lights. Turns over but fails to start. |
Relentless Member Since: 27 Oct 2015 Location: Yorkshire Posts: 8 ![]() ![]() ![]() |
Spent the past few days fitting the Ashcroft transmissions MT82 output shaft upgrade.
Battery has been disconnected the whole time whilst transfer box removed / replaced. Come to reconnect battery. I have no ignition lights. Landy turns over when key turned but will not start with no ignition lights. Handbrake light on, heater fan works, light and indicators work but no ignition. Checked every fuse.. even the under seat. Nothing found. Disconnected the earths. Sanded and refitted. Nothing found. Rechecked all transfer box wiring. Nothing found. At a loss now to what the issue could be. Any auto electricians any advice please?? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Does it have an aftermarket alarm? 2002 90 Td5 Station Wagon
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
loose relay under seat
bad connection on speedo pack Good luck! |
Standard alarm fitted.
I believe an electrical fault if holding of the ignition otherwise is would fire. Due to no ignition I doubt I have fuel pumping and glow plugs warming. |
Possible ignition switch failure? Could just be a coincidence that it's failed at this time. Otherwise check power to under seat fuse box
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Isn't there an earthing point on the gear box might you have damaged it or left it off? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Tried locking 4 times on the plip then an unlock? Solved the bowel problem, working on the consonants...
Recheck earth points all good.
Plipped alarm x 4times a few times. Starter relay works. (clicks in and out to heater plugs) Swapped main relays about with those under steering wheel. All fuses checked again. Still nothing!!!! ![]() ![]() |
white110 Member Since: 09 Dec 2017 Location: wales Posts: 10 ![]() ![]() ![]() |
Has the fuel cutoff solenoid got power to it ?
Which is the fuel cut off solenoid white110??
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8367 ![]() ![]() ![]() |
There is a large multiplug at the top rear passenger side of the engine, is that connected correctly? part of the loom coming off the engine. Cheers
Grey round one above heater box.... yep all in tact..
Scott R Member Since: 21 Jan 2016 Location: Northampton Posts: 25 ![]() ![]() ![]() |
I'm not really familiar with the tdci defender but I have seen this fault on the td5. Has it got a main fusebox with the bolt in fuses? if so take the cover off and check the connection for the main feed from the battery, I've seen the screw come loose and loose connection.
Bulkhead side of the injector pump, single wire.
https://www.youtube.com/watch?v=7C3UNVL0lTw edit: noticed wrong engine type after posting. 300tdi, loosen an injector pipe and see if fuel leaks, if no multimeter handy. |
