![]() | Home > Maintenance & Modifications > Anyone got the TF fender roof console? |
Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168 ![]() ![]() ![]() |
Mine has one fitted but I didn't fit it!
The light is useful as well as the storage ![]() |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
Ahh good! Stays in place? Doesnt wobble or creak? How big is the storage space? Could you post some pics please
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I have the original Outback roof console which Terrafirma one is based on. Main difference being that Terrafirma usedoriginal interior lamps
![]() ![]() Click image to enlarge It doesnt take up too much space. The rear lamp is a bonus ![]() If you have Mud rails or other versions under your seats then it will be in more view, but not an issue for me. I fitted mine for the same reason, though I originally bought it for mounting a Tachograph. |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
Hiya, wondering if you ever got one of these as a terrafirma version and could take any side shots of it, looking at romadog's one it does look deeper in section. I'm 6'2 and my brother is 6'7 so trying to figure out how much it drops down. Also, anyone know if it uses original fixing holes through to the roof reinforcement bar or does it need more holes creating in the headlining? EDIT: just found an image, but still can't quite tell what it's really like to use if you're tall. Plus there's no measurements i can find anywhere. Have added the image in. ![]() Click image to enlarge Hopefully final edit...... EDIT: Turns out most of the information on the entire internet is on the forum. You just end up going full circle ![]() ![]() ![]() https://www.defender2.net/forum/topic12005-30.html |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
Wow, that thing looks good and it's not even expensive... hmmm... could be another Lockdown project. Insta: @thebenjordan4x4
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 799 ![]() ![]() ![]() |
A friend of mine has one of these in his 110- it doesn't feel particularly well made.
Regards Chris |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56 ![]() ![]() ![]() |
I also have the Outback version, not the Terrafirma, so hope this helps.
I'm not quite as tall as those asking about the unit, but you never feel it intrudes into your headspace (Puma 110 with two standard front seats). The Outback unit is quite well made. It uses existing mounting points but yes you do need to trim visors - I did my own and was reasonably happy with the result. It also helps that you rarely look at the trimmed end! And, my unit is carrying an iCom radio, ie not zero weight, and has never felt like coming loose. Admittedly I don't do a lot of off-road/corrugations (it has done some) but it's just never moved. Measurements: it's about 240mm @ widest point, and it drops down 110mm deepest. Finally, a side-view photo, taken from the back seat: ![]() Click image to enlarge |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge
