Home > Td5 > limp - at 3mph??
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
limp - at 3mph??
Hi all,
Well a wet Sat eve in the New Forest and for the first time my trusty 05 75k mile 90 that has taken me to Switzerland and back - turns on the engine light and decides that I can go no faster than a hedgehog with a broken leg. At the time I had just bumped thro puddles on an unmade road - gently.
I need to know what to do first. I have no experience with this sort of problem
This post looks helpful
http://www.defender2.net/forum/topic37666.html
But also:
Seriously - is 3mph normal? I tried turning off, waiting restarting to no avail. After 90 mins and 2 miles or so I had reached a pub and stopped for a refresher and then - it fired normally.
And a tad disappointed that two defenders passed as I crawled with hazard lights on and... passed me. In the Rising Sun an excellent chap with ex army 300tdi - many thanks to him.
And - if it happened once I assume it will now keep happening till I fix it (or get a tdi)..?
So I really really want this to go away
Thanks all Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #685711 11th Feb 2018 8:34am
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi ppad,
I had this on my TD5, a small puddle and in to limp mode. Mine was traced to the crank sensor, mounted above the gearbox. New sensor and a clean of the plug, never happened again. A little bit awkward to get at, best if you can get it on a ramp.
Hope this helps
Anshyandy
Post #685724 11th Feb 2018 9:53am
roel
Mine get's wet sometimes but never had that problem yet.
So it must be fixable and not a permanent problem. Roel
2003 90 Td5 (2009-now)
Post #685753 11th Feb 2018 11:47am
bankz5152
Change the crank sensor for a genuine unit.
Post #685757 11th Feb 2018 12:21pm
miker
Sounds like it might not be getting a throttle pedal signal, so just sitting at idle?
Post #685771 11th Feb 2018 2:20pm
ppad
Thanks for the replies, in between hail showers had a wee peek and it's not oil in the electrics, so the two suspects of crank sensor and throttle pedal signal... 'not getting a throttle pedal signal'... maybe. 3mph that was the crazy part. If you are 500km from anywhere in Strzelecki desert it'd be a thirsty week. Idle indeed.
So in the morning off to Ben at Sway, if he has got a Nanocom. Will it tell me which?
Never got that wet in Aus, only this wet. An that was bad driving. Embarassed
Post #685839 11th Feb 2018 7:17pm
roel
If the engine light is on and there is no reaction on the throttle pedal. That might be the first thing to look at. If you switch it off and disconeect and connect again the black plug on the ecu. It might work again. Roel
Post #685846 11th Feb 2018 7:52pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
If you get some water/dirt on the MAF it can cause a kangaroo to get in control of the throttle.
Post #685861 11th Feb 2018 8:20pm
ppad
Took opinions ... crank sensor failure should stop the car (?) until the sensor decides to sense again. Diagnostic code / display of 'driver demand failure' and that the car went into tickover mode only .. suggest more to throttle pedal.
So this has been changed and now we wait and see. Being a sealed unit no way to physically know.
Ben in Sway reckons that my muscle memory is the problem Question ... each driver drives at exactly the same throttle position just from habit and will wear the sensor. Flamin' electronics. Sold the much modified 110 2.8, in Oz
Post #686731 15th Feb 2018 11:09am
miker
In the nanocom you can look at (from memory) engine inputs fuelling, then one of the pages shows the voltage on the throttle pedal tracks. It has either 2 or three tracks. Mine is the 2 track so:
1 voltage is always 5V (reference)
1 voltage is 0v when pedal up and 5v when pedal down
1 voltage is 5v when pedal up and 0v when pedal down.
The two variable voltages should always add up to 5v, if they don't then the ECU assumes pedal fault. I believe the three track uses a similar system with voting, ie voltages should add up to 5V or be equal.
Post #687118 17th Feb 2018 1:36am
roel
yes the 3 way ones has 1 track from 0 to 5 V and 2 tracks from 5 to 0 V. Roel
Post #687153 17th Feb 2018 10:03am
