![]() | Home > Technical > V8 Defender - Diagnostic reading 02 Bank1 Sensor1 - 02 Trans |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Suggest you join Defender 50th Forum and post this on there
http://www.defender50th.co.uk/index.php |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Certainly sounds like an o2 sensor playing up?
This may be of interest to you? ![]() 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
The 50th only has a single pair of O2 sensors at the front.
Ahh, didn’t realise that?
![]() Wanted, Forward Control Anything considered. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Wexford, if you give me the part numbers of your sensors, I may have one new.
There's 2 types of connectors to the loom.... I first got the wrong set... They're in my 'stock'! QRZ 2e0vpf |
Wexford63 Member Since: 10 Feb 2018 Location: Essex Posts: 2 ![]() ![]() |
Hi Everyone.
Thank you all for your advise. Initially, I had wondered if this may be simply a fault with the HT leads but with my failing eyesight I could not see any arcing on the leads but could hear a faint regular spark. I hadn't checked any further on that route after reading the information from my diagnostic readings. However, this morning I took her into a dark garage to see if I could see anything going on with the leads and there is a misfire on one of the HT leads. It's visually intermittent but if I touch the top of the lead with my finger it arcs to my finger. Not enough to make my hair stand on end, just enough to know there is a problem with that lead. The rest of the leads are perfectly fine......so with that in mind tomorrow morning I will be getting new leads and changing them. Fingers crossed, this might be the problem. Will let you know how I get on. |
