Home > Td5 > TD5 differences ?
voorfrank
Netherlands 2002 Defender 110 2.5 TD SW Bonatti Grey
TD5 differences ?
I was wondering if there are differences between a TD5 in a Discovery and Defender?
I know there is a p10 up to 2001 and P15 starting 2002 and on.
Can you take a P15 engine from a Discovery and install it in a Defender without doing any modification or what do you have to modify?
Are there people who have done this swap and advise me?
Frank
Post #681507 24th Jan 2018 11:07pm
Martin
Site Admin
As far as I can remember for swapping out my Defender spec 10P for a Discovery spec 10P was the outlet adapter on the power steering pump is different - you need to swap the Defender one over.
Also the Discovery turbocharger has a solenoid actuator on the wastegate vacuum pipe, which the Defender doesn't.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #681587 25th Jan 2018 2:02pm
roel
Hallo Frank,
I am not sure of there are any differences. If you want to replace aen td5 engine in a td5 Defender I think you can use a Disco engine. Any parts that might be different are probably around the turbo. The manifold might be different and the wastegate is controoled by the ecu on a disco and mechanical on a Defender. But you will have alle the parts that are different so that will not be a problem.
If you want to build it in your V8 ( I wouldn't understand why) you probably need a lot more parts as the dash is also ECU controlled so you have to change that too. And to get it working you might need a few more sensors, different fuel pump etc. Roel
2003 90 Td5 (2009-now)
Post #681588 25th Jan 2018 2:05pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Fitted a Discovery 15P engine to our 90. There aren't any differences really other than the ECU map, certainly nothing that will cause an issue. It's not like the 300TDi where the Turbo was in a different place. http://www.yorkshireoffroadclub.net/
Post #681590 25th Jan 2018 3:03pm
voorfrank
Hello,
Thanks for all the info.
I will go and buy a Discovery to get a new engine. Can you use the turbo form the Discovery and only change the ECU and waistgate meganism from the Defender or do you need to use the turbo from the defender too?
Reason that I need another engine is that on my way to the alps my engine died on the German Autobahn. There is a hole in the engine.It is a 2002 Defender with P15 engine.
Post #681927 26th Jan 2018 6:51pm
voorfrank
Last weekend I took the old engine out. so here some picks of the damage.
I also checked the oilpumb bolt and it is tight and there is no play on the sprocket. I think I just had bad luck.
Post #685647 10th Feb 2018 9:25pm
voorfrank
This week I bought a Discovery 2 of 2003. The engine sounded good, fluitds were ok, so I bought it and drove the car from Amsterdam home.
Today I started to get the engine out. The sun was shining so all was ok. Tomorrow unscrewing the engine mounts and belhouse bolts and I can lift it out. I am trying to sell some parts on Marktplaats.nl (the dutch Ebay) to gain some mony back.
Post #685650 10th Feb 2018 9:33pm
voorfrank
Lovely weather yesterday again so the engine is out. now I'm able to compaire the Defender and Discovery engines.
As far as I can see, all connectors are the same, except the Discovery has a turbo waistgate valve extra. Difference in the wiring is that in the Discovery the ECU computer sits on the right front under the bonnet and in the Defender it is in the right site seatbase box. this means thet the cables are routed different and so the lengths are different.
Now both engines are in the shed so this week I can clean the new motor and compaire them further.
Frank
Post #685954 12th Feb 2018 9:26am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I have just done this swap, as Martin said the Pas pump has a different union and the turbo has an added wastegate control all easily sorted, mine came with a/c so I had to remove the pump and fit the additional idler from my old block other than that it was all the same, if you look at my Buggsy thread there will be some pics of the swap Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #685973 12th Feb 2018 10:34am
voorfrank
Thanks for the info Mash.
Post #686049 12th Feb 2018 2:49pm
