Home > Puma (Tdci) > Tdci gearbox cluck on start-up
Landrover-jack
Hi all
Tried to find a "I'm new here thread" and couldn't find one.
Anyway last week picked up my new defender 110 double cab. On a 08 plate with 61,000 on the clock.
Started to pick up a few problem with it.
1st is when I start it up and turn it off I get a horrible cluck from the gearbox, if put my foot on the clutch and start it up it sounds perfect so must be gearbox related.
2nd is drivetrain backlash. I've nailed this down to gearbox output shaft as it sound like a fare few have had problems. Hopefully this will be sorted under the god awful warranty that I was conned into buying.
But other than that love the new tdci compared to my last td5 and 200tdi. Much more improvement.
Post #685369 9th Feb 2018 9:10pm
LR90XS2011
clunk is probably the clutch search clutch rattle DEFENDER 90 TDCI XS,
Post #685373 9th Feb 2018 9:18pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Welcome aboard, Wink
Going on what you say, I would put money on it’s the input shaft that’s worn?
Sadly an all too common problem!
I have had one of our work 110s recovered today, earlier in the week someone said the box was clunking on changing down
Through the gears, sure enough the backlash was quite bad!
Today, the input shaft failed and lost all drive while reversing up a driveway.
I’ve replaced a few as a precaution, including my own 2008 90 which I inserted a grease nipple into the splined cup,
And seems to work well.
It will be interesting to see how bad this one is, it’s been a heavy towing vehicle since new,
And has only managed 80,000 miles before complete failure.
It would pay to check the drive flanges while your there too,
Good luck with getting it sorted,
It’s a shame JLR won’t step up and address this well known and dangerous issue.
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #685385 9th Feb 2018 9:49pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Re: Tdci gearbox cluck on start-up
Landrover-jack wrote:
Hi all
Hi, try this thread http://www.defender2.net/forum/topic233.html Thumbs Up
Post #685425 9th Feb 2018 11:40pm
zsd-puma
The drivetrain backlash will likely be the adaptor shaft (gearbox output to transfer box), as well as play in the propshaft UJ's, as well as play in the Propshaft splines, as well as play in the Diff's as well as play at the end of the half shafts. It all adds up!
Adaptor shaft is usually the worst though and the biggest job to replace, mines been a lot better since fitting the Ashcroft kit. Later type one piece half shafts will also lose some more of the slop.
Post #685443 10th Feb 2018 1:29am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi and welcome!
Take it for a drive to get it warm and then stop in neutral. If you hear a 'clunk, clunk, clunk' but it disappears when you dip the clutch then it's most definitely the clutch more specifically the springs rattling.
Again, well documented on here although don't be rushed into doing anything - mine has done this intermittently for a considerable amount of time with no negative effect. Obviously if you are loading up your vehicle or towing heavy loads you may not wish to leave it to chance. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #685484 10th Feb 2018 10:58am
zsd-puma
It won't be the flywheel on a Puma Defender, unlike the TD5 or Transit they're solid flywheels.
Post #685496 10th Feb 2018 12:04pm
ozzie1989
Apologies, post edited to avoid confusion!
Not sure why I mentioned the flywheel when I meant the springs! Rolling Eyes Now: 2010 2.4 TDCi 110 Utility Wagon
Post #685500 10th Feb 2018 12:17pm
