Home > Tdi > Land Rover Wolf Donaldson Air Filter Mounting Bracket |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Should help
Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
31st Jan 2018 11:05pm |
Should help
31st Jan 2018 11:06pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 357 |
[quote="Mash"]Should help
thanks very much Mash. that's the right air cleaner box. have you got a page that shows the mounting bracket and part no for the mounting band (P777731, number 8 in the diagram) to fit on? The band is pretty large and needs to screw to something. thanks again 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
1st Feb 2018 6:25am |
Sorry for the delay Foxhound,
This is the only mounting in the AESPs, been a long time since I have worked on a deserterised Wolf to remember how it mounts Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
3rd Feb 2018 12:22am |
thanks for this. i reckon the AESP is missing something but i can bodge it.
in UK conditions, especially in the winter or on road, i can't see that the safety element inner filter needs to be used, am I right? not exactly extreme dust at present! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
5th Feb 2018 5:03pm |
It should be ok, after replacing a fair few filters like this in uk/ Germany the inner filter is often perfect with only the outer showing any dirt. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
5th Feb 2018 11:10pm |
Il try and do some digging on the mounting if your not in a huge rush
Seem to remember they are mounted at an angle, will trawl through some old photos and ask around to confirm. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
5th Feb 2018 11:17pm |
My thoughts were correct the filter housing is mounted at an angle;
Click image to enlarge Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
7th Feb 2018 12:01am |
thanks for this Mash
i got mine in this way i used the existing bracket and counter sunk the centre hole and ground the nut so it was flush and used 2 bands as only one end of a band would fit on the bracket to be bolted. Click image to enlarge Click image to enlarge 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Mar 2018 12:09pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1534 |
heres one on a 110 snatch 2a
Click image to enlarge |
18th Mar 2018 8:07pm |
