Home > Maintenance & Modifications > Headlight upgrade
scottchad01
Wales 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Headlight upgrade
Looking to buy some new headlights but don't have a large budget
seen these : https://www.getoffroad.com/land-rover/defe...t-defender
anyone bought from them before/had similar headlights?
thanks
Post #684289 5th Feb 2018 3:12pm
leeds
Cheap and cheap for a very good reason. NOT ROAD LEGAL
They do not carry an APPROVAL mark as required by UK Vehicle Lighting Regulations
Also by UK Vehicle Lighting Regulations you are only allowed ONE indicator per side at the front of a vehicle.
Not having road legal lights apart from it being an offence under section 66 of the RTA to supply, fit or use a defective item you are more then likely in breach of your motor insurance policy and run the risk of it being voided.
My advice would be to either upgrade wiring loom, bulb/reflector or save until you can afford ROAD LEGAL LED headlights.
Brendan
Post #684293 5th Feb 2018 3:28pm
scottchad01
Thanks brendan for the help, will probably wait to change the headlights then and spend money elsewhere on the truck
Post #684294 5th Feb 2018 3:30pm
miker
Assuming you have the original quad optics (with the textured lens) then a great cheap upgrade is wipac crystals and a relay loom to bypass the shockingly bad standard switch!
Post #684300 5th Feb 2018 4:04pm
