![]() | Home > Series Land Rovers > Series 1 88” rebuild |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 779 ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11015 ![]() ![]() |
Very nice and thank you for sharing your project, as many on here, will be watching with great interest
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Good to see your finally making a start on it Andrew,
I know it won’t take you long to sort it. Keep updating the pictures. ![]() Wanted, Forward Control Anything considered. |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
Nice one Andrew,where did you get the new bulkhead from 😳
Stephen. |
Thanks Ian.
The bulkhead was made by Jean Dexter which wes supplied by Tom Pickford(www spares.co.uk) |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1399 ![]() ![]() ![]() |
Nice - and you made it to the Wicklow Way too! Euro-Leafing to infinity and beyond.....
Made good progress today, but it’s always quicker to strip down than rebuild.
Didn’t even need the disc cutter much. ![]() Chassis is not too bad on initial inspection but the bulkhead is well past it’s sell by date. ![]() Click image to enlarge ![]() Click image to enlarge |
Another good day, going back together now.
You will be up and running for the weekend Andrew!
How bad was your chassis in the end, Are you keeping it for a rainy day? ![]() Wanted, Forward Control Anything considered. |
Ha, ha don’t think it’ll be running by the weekend, but won’t be far off hopefully.
The chassis isn’t as bad as I feared. Needs a new x member, rear tank outrigger and a couple of old repair patches replacing. Not sure what I’m doing with it yet, but it won’t be scrapped yet. The bulkhead is a different matter...... |
Sounds like it’s worth hanging on to, it can be another project!
Looking good Andrew
![]() Stephen. |
Piggle Member Since: 24 May 2015 Location: Surrey Posts: 82 ![]() ![]() |
Likewise - following with interest!
![]() Click image to enlarge ![]() Click image to enlarge Split the engine/gearbox and found clutch is fine so put engine back in on new mounts. Gearbox back in, with a bit of huffing and puffing. Brake lines on and connected. New pedal shaft, bushes and clutch relay shaft. Finally, offered up the new bulkhead at the end of the day and it fitted first time, much to our relief. I've tried some 3mm on the bulkhead and was impressed how well it went one. Looking forward to see how well it works. Wiring tomorrow ![]() |
