![]() | Home > For Sale & Wanted > Wanted - 90 TD5 SW |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
A good friend has finally been converted and is looking for a decent 90 TD5 station wagon, with budget up to £12k.
What have you got or seen? Also, what should you specifically look out for on the TD5? Thank you. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
Hello James, I have a 2003 TD5, my tips based on experience are to check the fuel pressure regulator is dry, that there isn't oil in the ECU plug under the drivers seat, that the vacuum pump / alternator isn't dripping oil, that the front swivels are in reasonable nick, that the bottom of the front doors aren't rusted through, that the heater works, that the rear cross member looks ok and everything works! Oh and finally the 15p engine is the one to go for. Also check the online Mot history, happy hunting cheers Andy
That's brilliant, thanks very much Andy. James
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Just put my TD5 up on pistonheads a pickup if it’s of interest
https://www.pistonheads.com/classifieds/us...00/8328196 Not a station wagon but near as dam it a new vehicle. |
Thanks Mark. I'll pass it on. James
td590brad Member Since: 30 Nov 2014 Location: Sussex Posts: 203 ![]() ![]() ![]() |
https://m.ebay.co.uk/itm/1999-Land-Rover-D...SwJc9aahLV Was Td590brad.. then pumabrad... then back
Yours Brad? James
Yes Was Td590brad.. then pumabrad... then back
