Home > In Car Electronics > Should I be concerned
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Since I have owned the Defender (>1yr) its had a constant issue with the battery terminals being crusty and a tendency to run low on power quickly.
I have done a voltage drop test on the connector and found it to be ok. So I continued with it. Recently I noticed it was at times reluctant to start (clunk but not start) so I popped into a Halfords and got the chap there to do a load test on the battery and it turned out power from the alternator was good but the battery was failing under load so I bought a new battery.
Well, last night I went to start the damned thing and it failed to start so I attached the new battery and tried to use it to jump start it. That failed, so I tried a local mechanics jump starter thing and that failed. So in the cold dark, I swapped the batteries over but it didn't go to plan as the old battery terminal was intermittent and it would still fail to start. But I managed to get home by using the jump leads to get an ok connection.
So today I replaced and remade the connections and I oped for a different style of battery terminal and connector. All is well.
The only problem was when looking at the brown wire in the ribbed sheath (goes towards the CDI etc) I noticed it was scorched but for only 5cm and goes around the wire following a few strands. Now the sheath is in OK and no signs of damage but do I need to worry about this? do I need to replace the wire?
Post #683870 3rd Feb 2018 6:38pm
Replacing would be ideal, but not totally essential (I'd replace). But needs insulating obviously. Inspect where it's come from for whatever has cut/rubbed it and solve that too. QRZ 2e0vpf
Post #683886 3rd Feb 2018 7:16pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Has the wire got hot because of poor battery terminal connections. On a dumper I have similar issue where sheathing almost melts if the connections are poor
Post #683890 3rd Feb 2018 7:34pm
JustFX
Greenie, the wire is in that ribbed trunking so the wire damage is just from a melting session.
I think I may well look to replace. It looks like an old injury but might have been a incorrectly connected battery during jump starting I guess.
Post #683892 3rd Feb 2018 7:48pm
Ah got ya:-) QRZ 2e0vpf
Post #683893 3rd Feb 2018 7:55pm
That melting is caused by high resistance, the higher the resistance. (Bad connection). The higher the current draw.
The higher the current draw the higher the excess heat, in this case that cable must be very near it's current capacity if not exceeded.
The fuses should blow before too much cable melt has occurred.
Has there been any fuses blown or replaced?
I had at one time, a battery clamp that was loose, I believe it was earth.
It shouldn't have been but it was, but in my case it failed to start and all you would get is a Relay click.
There was no reason fo it being loose, but the factory clamps are not the best, so after carefully slightly flattening the battery post with a hammer. (Only a little, as they are soft lead).
The battery clamp could go on, tighten up and then had no problem from that day to this.
I don't know if fusing was blown in this case or not, but if you do get a fuse blow you have a significant short.
And the answer is to trace the fault ASAP, not just fit another fuse.
The fusing being there is a safety feature, without them you will get a fire in an event of a short.
They are supposed to protect the cable and not specifically the device that is powered. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #683903 3rd Feb 2018 8:41pm
sako243
@custom90steve, sorry but that's plain wrong. Go back to basic electrics and Kirchoff's voltage law (V=IR). If resistance goes up then assuming an ideal voltage source (which is what a battery is ideally) then current has to drop. In reality the voltage will also drop as nothing is ideal*.
Think, why do you normally refer to current limit resistors as limit... Because they limit the current. Admittedly if you have a parallel resistor network then a crappy connection can make one path higher resistance and therefore try to pull too much current through the other paths.
Edit: * if the current draw is large and pushes the capability of the battery. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #683906 3rd Feb 2018 9:01pm
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I had problems with my battery on my '87 200TDI. Cut a long story short, it was the cheap Chinese terminal connectors i got off ebay. I ended up changing those for some decent ones and 'that' electrical problem has now gone.
Post #683916 3rd Feb 2018 9:39pm
JustFX
This is a TD5 and was on standard connectors. I bought decent connectors of the right metal mix to go on there so hopefully no repeat.
I am guessing that is where the interior gets its power. and I haven't had a fuse go there so I doubt its draw from there. I know Discos had an issue if the engine earth was bed it would draw from the loom and kill it.
I did once note the battery terminal was getting hot and that is when I did a volt drop test. But I guessed the heat may have been because the battery was rather low on power so was getting a real charging. I did clean all the contacts.
Guess I need to find some more 16mm2 wire of the correct length to replace it as now I know of the burn mark I think its best to fix it.
Post #683933 3rd Feb 2018 10:17pm
sako243 wrote:
.... Go back to basic electrics and Kirchoff's voltage law (V=IR)....
I think you'll find that one was down to Georg Simon Ohm and bears his name.
Gustav Kirchoff was more into conservation of energy theory as it applies to circuit theory.
Post #683944 3rd Feb 2018 10:47pm
sako243
I stand corrected. Been a long week... Bow down Ed
Post #683948 3rd Feb 2018 10:49pm
