Home > Puma (Tdci) > Air Con (Or lack of it!!!)
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Bought my 110 puma new last year. Never really used the aircon until now ( Too bloody cold during the winter) . I Know the heater works as it quite merrily scorches my left ankle. But the aircon on cold does not seem to make any difference to the normal cold blower. Are they all rubbish or is mine "Cream Crackered". It's due in for the hand brake recall so will mention it then, but was just wondering, as other cars i've had with aircon make the interior like a fridge during hot weather, or is it just a land rover thing?
Steve
Post #68380 23rd Apr 2011 7:39pm
mse
Mine always got really cold Mike
Post #68381 23rd Apr 2011 7:49pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Mine gets very cold, my wife wanted it off today Shocked BM52
Post #68383 23rd Apr 2011 7:56pm
john adam
France 2010 Defender 110 Puma 2.4 SW Keswick Green
Mine it is cold but not too much, expecially during a hot summer in Sicily.
Carlo 1971 88 Series IIA somewhere in Southern Italy
1989 Ninety stolen in Paris
2004 90 TD5 gone
2010 110 S Puma TDCI running
Post #68385 23rd Apr 2011 7:58pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Re: Air Con (Or lack of it!!!)
Make sure heater circulation lever is pushed al the way to the left (recirculate). Also, I find it works best when air direction knob set to point directly to face (or face and feet).
Then set to maximum cold.
I find mine takes approx. 10 mins. to get really cold, but when it gets there, it's cold enough!
Steve
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #68386 23rd Apr 2011 7:58pm
biffabacon67
Thanks guys, sounds like mine is definately faulty, have tried all the different blower positions and vent combinations, but no joy. Oh well, the one and only fault in 12 months other than a blown fuse. Can't have everything.
Cheers again
Steve
Post #68387 23rd Apr 2011 8:14pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
You need to use air con regularly (e.g. at least once a week for half an hour or so) or the seals dy out and the refrigerant leaks. At that point the air con stops working. Get your local dealer or air con specialist to check it out and see if the pressure is low - they may be able to just top it up if you're lucky, if not you may need new seals.
Air con is helpful even in winter as it dries the air and helps de-misting. Hope you're able to get it sorted.
Post #68390 23rd Apr 2011 8:51pm
biffabacon67
Hi Cobs,
Cheers for that. But surely it shouldn't happen on a vehicle that is not yet 12 months old?
Post #68391 23rd Apr 2011 8:53pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
age is irrelevant, the handbook probably states that it needs regular use, you wouldn't not check the oil for 12 months and then say an engine should not sieze on a vehicle only 12 months old, Thumbs Up
Post #68393 23rd Apr 2011 8:58pm
cobs
Quote:
age is irrelevant..
as kingofthesparks says - of course it could be something completely different but I'd start by looking for leaks
Post #68398 23rd Apr 2011 9:13pm
biffabacon67
True, very true. Cheers, will get it checked out. Although i must admit i've never seen any puddles or tell tale stains under it. (A first for me in my previous landrover ownership Laughing)
Post #68400 23rd Apr 2011 9:20pm
kingofthesparks
you wont see any leaks as the leaking is a gas not a liquid, or so i am led to belive,
Post #68402 23rd Apr 2011 9:24pm
biffabacon67
Ah Ha. Well it's in for it's recall, so will definately get it sorted.
Cheers all.
Post #68405 23rd Apr 2011 9:41pm
biffabacon67
Didn't realise it was so long ago, but here's an update. Took it in for brake recall and service (Which was done), and also mentioned the air-con and some corrosion issues (Hinge bolts, rear step and strip along the bottom of rear load bay). Anyway they have now booked it in for an entire week to sort/replace a faulty air-con compressor and the rust. Seems like a hell of a long time, or is it just me?
Also, after the service it seemed a hell of a lot smoother, would it have had the ECU altered? On the motorway it also seemed to be faster before the speed limiter cut in. Is this just rose tiinted spectacles or could it possibly be?
Post #86494 29th Aug 2011 10:16am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
If under warranty they would of updated the ecu software to latest spec [which is a lot better] so yes probably does drive better Very Happy
Ref Air con - mine didnt work from day 1 also , like your's it was a faulty compressor. not that uncommon apparantly Whistle Guns and Landrovers .... anything else is irrelevant.
Post #86496 29th Aug 2011 10:20am
