![]() | Home > Tdi > 1995 300tdi vented discs or solid? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
My car is a 1994 110 SW 300Tdi. It's vented at the front, solid at the rear. I imagine this would be the same on a hardtop of the same era - but I'm afraid I couldn't say for sure. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
Your 110 should have vented, though in 23 years previous owners may have fiddled with it.
But if you’re buying both calipers and discs then just get vented anyway as those are the only parts that differ. |
horus1970 Member Since: 27 Jul 2016 Location: north east Posts: 105 ![]() ![]() ![]() |
Thanks for that lads, just wanted to make sure axle mountings weren’t different
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5348 ![]() ![]() |
are you getting braided hoses too? that would be another upgrade to do if you are sorting out the brakes
![]() One thing is why the hell do defenders have the solid discs at the front? Id have thought due to the weight and what they used for, they would have vented at the front. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
110s have since the 300Tdi always had vented as far as I know. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
You can put vented on with 110 calipers. My puma, being a truck cab has solid discs, so I'm converting it to vented, I did it with the v8 too. QRZ 2e0vpf
I’ve just bought a full set of vented front discs and new calipers and new rear solids with new calipers, will buy some braided hoses too, like you say I might as well put the braided ones on while there off and getting changed,
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
I've fitted vented discs to the rear also using brackets from red.winches.com I'm building it into a camper which will be quite heavy + I'll reduce the service parts I need to carry.
im making mine into a camper too, hopefully ready for summer,
