![]() | Home > V8 > Every day V8. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3855 ![]() ![]() |
Hello
no idea on if its possible but my dads old range rover was a TdV8, he got between 30 / 35 mpg and it could move when needed. Would that fit in a Defender? best of both worlds a V8 and MPG over the teens ![]() Then looking for electric motors for my lads toylander I was surprised at the searches back, Lexus 450H engines, 3.5 V6 but battery also... Had me thinking...could that fit a defender? I'm sure most things are possible its down to ££ |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Yes had a V8 and used it as a daily drive, briefly, when I was doing 35,000 miles a year. It was costing more to run than I was getting paid so that didn't last long.
However I put the V8 back in it again and now it is my only car, has done 60,000 miles, since I put a V8 back in, without having a spanner on it other than to replace oil and filters. The only suggestion I would make is to see if you can find a 4.2, much nicer to drive than a 3.5. If I drive it gently I can just about scrape 20 to the gallon from it. If I don't pay attention it dips to around 17 and if I do a lot of town work it gets about 14. Loading it up doesn't seem to bother it, neither does towing a trailer, headwinds are a killer though, economy drops markedly Last edited by oneten110 on 1st Feb 2018 10:02pm. Edited 1 time in total |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1311 ![]() ![]() |
Well, you could always do what the factory did (occasionally):
![]() Click image to enlarge 2.5 petrol, low tech and sort of economical. If it didn't accelerate like a slug on diazepan, I would recommend it. ![]() |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
I run my 3.9 V8 every day, love it!
Remember the Rover V8 is an old lump so really needs a good overhaul/ rebuild. My current lump is proving reliable but could do with a freshen up. Fuel economy is rubbish but I really don’t like diesel so I live with it |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
Thank you all for your reply's, a lot of thinking to do
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
I've had the exact same thoughts myself. After a bit of research it came down to the Toyota/Lexus 3UZ-FE 4.7 V8. From what I've read a very reliable engine, VERY tunable and returns decent-ish MPG (25 - 35mpg, so TD5 MPG) Plus seems to have a similar torque curve as the TD5 which is a big bonus in a Defender.
Reasonable power output too sitting at around 350bhp and 500nm which keeps it sensible both power & money wise. Syncro Gearboxes do an adapter plate for the R380 for the 1UZ (which is very similar to the 3UZ) which means the engine will bolt to the R380. So no super expensive gearbox/TX box to worry about nor the fitting. Equally with the reasonable power levels the standard drive train should be up to the task, at least for a while, if you don't drive with a lead foot. Otherwise off the shelf bits & Syncro Duraspec boxes would up to the challenge. Should you want to go full blast one day, there are bolt on superchargers/twin turbo kits and the engine can produce 500bhp+ with ease. Engines are available for £800 - £1.5k depending. Shall be the route I go down if my TD5 goes bang or I'm taxed out of owning a diesel. 1UZ conversions have been done many times in Defenders for challenge trucks and buggys, much cheaper engine (£500+) but different torque curve much higher up the rev range. So a lot of the hard work has been done |
Hi bankz5152, thanks for your info, i have heard/read about the toyota/lexus engine in defenders and always with positive outcome
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
I wish I could drive mine as a daily..... We'll have a v8 in our daily soon.
Watching with interest Clayton. QRZ 2e0vpf |
^^^ LR ? Clayton.
Not this year, next ...(though stranger things have happened) but LS. QRZ 2e0vpf
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Interesting reading
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
^^^ It is James
![]() Thanks GREENI ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
low tech ![]() ![]() |
Not seen any advertised in the same way as the LS jobs but there will be companies out there that will do it. (4x4 fabrication will) considering its not as complex as an LS swap I would probably have a go myself. 1UZs are very popular as a very cheao engine and still pretty decent |
