Home > Tdi > water leak, header tank split??
horus1970
England 1995 Defender 110 300 Tdi HT Portofino Red
noticed a pool of water just behind drivers front wheel, traced it to header tank, seems to be wet on the bottom of header tank take it there is a hole or crack in it,, is there an aluminum after market one someone can recomend please,
Post #683177 31st Jan 2018 5:25pm
Have you checked the hoses and connectors?
There are Ali alternatives but downside is not so easy to check fluid levels.
I think an alternative is Alisport but don’t quote me on that. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #683183 31st Jan 2018 5:53pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Was your old header tank black or white? I heard the black ones were prone to splitting along the seam but the white ones were not.
Alisport appear to make tanks with viewing gauges built in. Not cheap but very smart Cool 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #683192 31st Jan 2018 6:23pm
horus1970
mine is black, i have had a quick look at hoses and they seem fine, water was coming from under header tank, fingers were wet when i pushed them under tank,
it also seems to have had some kind of black sealant smeared around the equator of the bottle where the two pieces join? dont mind having to open tank cap on ali one as mine is black and have to do that anyways, is this a common problem?
Post #683196 31st Jan 2018 6:39pm
Harry-o "Alisport appear to make tanks with viewing gauges built in. Not cheap but very smart".
Oh yes, I remember now forgot about that.
I just realised that this was for a TDi too, I was thinking Puma at first. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #683198 31st Jan 2018 6:40pm
Litch
I had an Alisport header-tank but after a couple of years replaced if for my original (white plastic) one.
No real reason but it didn't do anything that the OE one could not do and I prefer the standard look (even my silicon hoses are black). ONE LIFE, GET IT!
Post #683222 31st Jan 2018 8:08pm
horus1970
just bought an alisport one, i dont mind how it looks as long as i know it wont split again ha, cheers for your help lads,
Post #683434 1st Feb 2018 4:00pm
Mo Murphy
An expensive solution to a known problem, the black tanks are prone to splitting, hence LRs change to the white material for the tank.
The Allisport item is very shiny though 😉
50 Shades of Pennine Grey
Post #683454 1st Feb 2018 5:53pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Correct. The black tanks were changed for the white ones due to a bout of splitting around the middle seam. Never seen a white one split in umpteen years, right up to when the export Tdis were discontinued in 2006.
If you want to replace part of the cooling system with something shiny that has a real function, get rid of the plastic bungs in the thermostat housing and the top of the rad and put metal ones in.
Post #684227 5th Feb 2018 12:57am
horus1970
Any ideas where I can get metal radiator plugs from mate? Cheers
Post #685043 8th Feb 2018 5:25pm
dorsetsmith
Post #685199 9th Feb 2018 8:29am
BogMonster
If you want some really bling ones
https://www.flatdoguk.com/x-cap-radiator-cap-red~1433
The brass ones are just as functional, but the X-Cap can be removed with a 27mm wheelspanner or a large screwdriver, which may appeal to the Bear Grylls within you, if you maintain it's essential to be able to do a coolant change in the middle of nowhere Wink
Post #685222 9th Feb 2018 9:52am
horus1970
Thanks lads will get the brass ones as I love easy serviceable bits on my landy,
Post #685271 9th Feb 2018 1:36pm
