Home > Maintenance & Modifications > Repair to Torn Out Rear Mudflap
hank
As is common on 110's, my rear mudflaps have torn through their mounting hole in the rear arch return.
A quick fix might be some repair washers above and below but this doesn't close the tear so the bolt can still slide out if pulled.
I'd like to strengthen the area so was going to put a length of aluminium angle along the arch/return. Can anybody see any reason not to do this?
My thoughts are that perhaps the 'tear' is an intended weak spot/failure mode? If the bolt was not allowed to tear out, perhaps it would pull the wing inwards?
Thoughts appreciated
Post #682890 30th Jan 2018 2:09pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I suspect that the tear out issue is Landrover throwing away the book titled "Bi-metalic corrosion in the motor industry" and using a steel bracket bolted to an aluminium body panel in an area which will (at least in the country it was designed and built in) be subjected to water and other wet things on an almost daily basis.
I have fitted the Gwynn Lewis kit to mine including the rear crossmember mud shields. The brackets for the kit are 3mm thick galvanised steel and come with reinforcing brackets for the bottom edge of the wing.
The instructions also give plenty of advice on getting plenty of the specified grease covering it to form a barrier and prevent further corrosion. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #682891 30th Jan 2018 2:18pm
ericvv
Surprised that this still happens to 110s today, this has been commented here for years in numerous threads. There is a easy to install and cheap solution available from the likes of Nakatanenga and Entreq in the form of a set of cheap SS brackets with the required insulating strips and paste to avoid bi-metallic corrosion. Price is less than 20€, and if installed from new or before real damage takes place they avoid all damage to the 110 rear arch panels. I think in the UK also avalable from Brendan. For all those with 110s who do not have these yet, get a set of those and screw them on without delay. Very easy. Pictures of the Entreq version below.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #682901 30th Jan 2018 3:05pm
hank
I have seen you recommending these in other threads while searching. These are £33 + £5 P&P... £38 for two bits of plate?!
I have a couple of metres of aluminium angle in the shed from another project...
Post #682913 30th Jan 2018 3:54pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Thumbs Up for alloy angle, used this to repair mine about a year ago, still ok.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #682927 30th Jan 2018 5:08pm
zsd-puma
^^^^Don't mess about just fit this kit ^^^^.
The standard brackets rot out after a few years anyway even if you repair the tub side. And most of the mud thrown from the wheel just gets chucked over the top of the mudflap and makes the rear cross member rot. The Gwynn Lewis kit stops all that, it's pretty much fit and forget, the brackets and reinforcements from Gywnn Lewis all all hot dipped galv, doesn't react with ally like stainless.
Post #682987 30th Jan 2018 8:55pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I had this problem a few weeks ago and used a length of aluminium angle iron cut to around 200mm. I then drilled and riveted it in 4-5 spots. Refitted and you’d never know ! Should last a while
There was no way I was paying £30 for a couple of metal plates , bonkers
Post #683057 31st Jan 2018 1:38am
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Why is it people on this forum throw money at repair kits. As others have said too I just pop rivitted a small bit of Ali angle into the wing and refiftted the bracket, its been there for 5 years now without a problem He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #683082 31st Jan 2018 10:21am
hank
Alu angle it is Thumbs Up Thanks
Post #683083 31st Jan 2018 10:29am
Post #683103 31st Jan 2018 11:58am
bluebottle
Another +1 for angle aluminium. Did mine and pics in My Defender thread.
Some Naka stuff is nice, I was prepared to shell out for their leather door handles but £33 for two small strips of SS.. Rolling with laughter
Post #683105 31st Jan 2018 12:26pm
hank
Thanks for the link Supacat
Post #683118 31st Jan 2018 2:03pm
Cupboard
Cheap way to reattach the mudflap is the aluminium.
Good way to solve the problem is the Gwyn Lewis kit.
Post #683327 1st Feb 2018 4:05am
agentmulder
Kuwait
Ali angle Thumbs Up Thumbs Up
If I recall I ground some flats on the edge of some washers as well. Not sure where they ended up and it's raining Laughing Solved the bowel problem, working on the consonants...
Post #683344 1st Feb 2018 8:47am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
+1 for aluminium angle, I repaired the “repair” the dealer carried out and riveted and bonded a piece of angle to the inside of the wing to reduce the to close the crack where road salt and crud could collect. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #683347 1st Feb 2018 8:48am
