Home > Technical > Heater starts alarm
Lowe
Denmark 1999 Defender 110 Td5 SW Corris Grey
Heater starts alarm
My "new" defender has a webasto diesel pre heater.
When using the heater the car alarm starts after app. 15 minutes
The voltage at the time is 11.91v and the blower is running.
Has anyone had this and is there a cure
Post #683003 30th Jan 2018 9:40pm
jst
i have a webasto engine heater and int heater in mine, neither make the alarm sound.
thats with the screen demist an setting an fan on when using the engine heater
the cabin heater (Air top) has the vents directed down
Is it a std LR alarm?
is the alarm sounding for low voltage? not even sure if this is a feature?
or sounding from air movement?
are you on demist (air up) or to the footwells? or does alarm go off on both?
i am more inclined to think its voltage linked as it takes 15mins. the fan comes on when the coolant is at a certain temp, but that would happen prior to 15mins i would of thought. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #683011 30th Jan 2018 10:14pm
Lowe
Today i changed the battery to a brand new one fully chargede.
Started the heater, and 10 minuts later the alarm went of.
So what can it the bee..
Can the alarm be disarmed with my nanocom ?
Post #693587 15th Mar 2018 7:46pm
Heat waves setting off the internal sensor?
Post #693590 15th Mar 2018 8:01pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Tape over the ultrasonic sensors and try it. V8 90...WIP
Post #693601 15th Mar 2018 8:30pm
I might be getting mixed up between vehicles but I thought there's an alarm/lock option that disables the interior alarm - for when you want to leave a child/pet inside?
Post #693701 16th Mar 2018 8:43am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
If you lock the car by the key in the door it arms the perimetric alarm and not the volumetric internal alarm so should disable the internal sensor but keep the doors and bonnet protected.
Post #693706 16th Mar 2018 8:56am
Lowe
Thanks, now i have some more to go on..
Post #693852 16th Mar 2018 9:11pm
jst
my webasto heater air flow set the car alarm off in my '99 td5. i just pulled the wires on the volumatric alarm. locking by key didnt disable on that one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #693971 17th Mar 2018 10:32am
To be fair, I think jst got you there 1st time:
Post #693988 17th Mar 2018 11:29am
Lowe
Solved..
Pulled the plug from the volumetric sensor and now we can heat up without waking up the neighbors..
Post #695027 20th Mar 2018 9:46pm
I guess the next question should be whether the sensor can be moved, the sensitivity of the OEM one adjusted or can be swapped out for one that mirrors the dual tech ones you get for conservatories?
My RRS had the pre heat facility and never set the interior alarm off so maybe the electronics disable the sensor on start up or it's a different type of sensor?
Post #695126 21st Mar 2018 8:17am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Perhaps a cut out relay that cuts the wire to the volumetric when the heater or fan is running?
Post #695268 21st Mar 2018 8:15pm
Lowe
Suits me fine that the sensor is disconnected, then it dosn“t start the alarm if the dog moves around.
Post #695368 22nd Mar 2018 8:40am
