![]() | Home > Maintenance & Modifications > Boot storeage improvements |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
I'm currently going through something similar!
I like the tuff trek idea. I recently picked up some side cages and a chest to increase the storage ... Just need to find some time to install now. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4296 ![]() ![]() ![]() |
The Tuff Trek rack is excellent on the whole, fits with no drilling. It does rattle quite a bit when empty though, but you can reduce that a lot with a couple of simple tweaks. It obscures the interior light when there is stuff in it too, again not impossible to overcome. 2007 110 TDCi Station Wagon XS
jrw Member Since: 25 Oct 2017 Location: Cumbria Posts: 34 ![]() ![]() ![]() |
Looks great - might well be in the market for something similar, once I get my Defender. 2014 110 XS Utility
2017 D5 2012 FFRR TDV8 |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Will give a thumbs up for the Karoo carrier. Had one since they launched it early last year absolutely super
Sphere. If yours rattles a lot , especially when empty, put heat shrink sleeve over the slide bolts where they pass through the the metal frame, quitens the whole thing down nicely. 2007 110 TDCi Station Wagon XS
Tbh don’t have any rattled apart from when I put something in there and forget to bungee it in place.
Mine has rubber grommets where the slide bolts fit the frame? |
Fair enough. Mine has the rubber grommets too, it the other end of the bolt where it goes through the basket, no grommet there. 2007 110 TDCi Station Wagon XS
Hunky Gibbon01 Member Since: 20 Mar 2017 Location: Dorset Posts: 90 ![]() ![]() ![]() |
Silly question. I've got a 90 station wagon with folding forward seats. Does the Cargo carrier impinge loads for passengers headroom aka no passenger if it's fitted and remove the seats?
It would definitely impinge on head room of anyone in tha back. 2007 110 TDCi Station Wagon XS
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
What’s this? Can you give us a link ![]() |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 ![]() ![]() ![]() |
Interested to know what you used for the platform across the load bay as well.
Kargo Karrier here http://tuff-trek.com/vehicle-accessories.html 2007 110 TDCi Station Wagon XS |
Platform was mostly made from leftovers I had lieing around. Two lengths of cheap steel box section bolted through where the third row seats fix. Just one bolt at each end, so Four in total. I used stainless bolts as they are exposed in the wheelarches. Those provide the support. The platform itself is 20mm marine ply with carpet glued to the top face and aluminium angle crewed round edges. Carpet matches the defender exactly and it’s sold by some guy I see at every LR show for not much. Made them in two pieces just for ease of handling and storeage. Those fix to the steel box section with four bolts each. And that’s it really. 2007 110 TDCi Station Wagon XS |
