Home > Maintenance & Modifications > headlining removal...
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
tips before i f**k something up.
i'd like to remove/refit the headling section just above the driver/passenger, in order to mark, drill and attach two small cargo nets above the seats for sunglasses, tat etc.
i've got the right plastic clip 'tugger', and see that the mirror unclips and the sunvisors unscrew.
what else do i need to know, before i set to... tips and advice anyone
Post #68266 21st Apr 2011 10:29pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Common sense really - go slowly and "ease" things out, even when they jam up (and they will). I would also get a few spare clips just in case any break. PITA if you are left with sagging roof because the last clip snapped off...
mounted a dvd player for the kids right in the middle, and had sweaty hands the whole time!
good luck 2001 TD5 110 DCPU in Bonatti Grey
Post #68274 21st Apr 2011 11:29pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Be aware the clips are £2.86 each Shocked You may find that the screws that hold the mounting plate for the mirror just turn in their holes. Wear gloves to stop dirty oily finger prints getting everywhere. Whislt you are in there put some clear waxoyl round the holes that are roughly drilled for the plastic fir tree clips. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #68292 22nd Apr 2011 8:24am
