![]() | Home > Off Topic > It's an LED Jim, but not as we know it....! |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1893 ![]() ![]() |
So,
I got an LED security spotlight on Amazon, £80 or thereabouts. Not long after i fitted it, some of the 'lines' of LEDs started to go. I got a prompt refund from the seller, and they weren't bothered about getting it back so it's just been up there, slowly fading away as more and more of the LEDs failed. Now, it's completely dead. Replaced it today with a smaller, cheaper thing from Wickes.... let's see how long that lasts.. But... the same mental condition that makes we want to keep on fixing and improving an old Land Rover has kicked in. I've take the light apart. (I kid you not, the reflector is effectively a steak pie dish!) But this is the LED unit. ![]() Click image to enlarge Two soldered connections, some flexible silicon-like adhesive and some white grease-like stuff which I assume is a heat conducting paste. The light was supposed to be 80watts - and it was pretty bright to start with. There are 100 LED 'chips' on the panel so presumably 1.25 watts per unit.....? Maybe. Anyway, my questions goes out to anyone involved in LED trickery like this. Is a unit like this readily available? I assume so - and a lot cheaper than £80. I reckon I could easily put the thing back together again. As always, any advice gratefully received. Ta. D Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Chances are pretty high that it's dry solder joints. Might be worth heating with a hot air gun to re flow the solder. Might bring it back to life
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Could certainly try that - never thought to photo the other side - it's actually a piece of aluminium. So the solder joints would be in the middle somewhere? Donald
It's probably dibond to provide a simple heat sink
Thanks Grafty, do you mean the white paste, or the 'aluminium'? Donald
I would imagine that they're mounted on dibond plastic, it's a layer of plastic with a thin layer of aluminium bonded on each side.
Without seeing it in person it's hard to tell.... 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Incidentally the panel looks perfect defender interior light size
Yea - that occurred to me too! Would be absolutely blinding!
Here's the other side of it. Without getting a magnifying glass onto it, it does look like it's a one piece thing rather than a sandwich or laminate but I guess not. ![]() Click image to enlarge Reckon the heat gun would still work here? If not, what should I google to find a replacement? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Looks like I can see layers there so could be dibond. Heat gun on the led side. Not too much heat but enough to melt the solder. I suppose as it's broken already you have nothing to loose
![]() Not sure where you'll find a replacement 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
