Home > Puma (Tdci) > Master clutch cylinder leak
Eduardo
Hi there,
Today I found some a small amount of oil (less than 0,5 cc) in the footstep down the clutch pedal. So, master cylinder should be leak. Sad Sad
I think that some of you had the same problem and I have several questions:
Can I drive safely for some time taking in account that there is not any trouble in change gears, etc.?
After the leak start: How much time can take until the cylinder will stop to operate?
Can be repaired or should be changed?
I'm out of the warranty, so will be at my own cost Evil or Very Mad
Thanks! Eduardo
Post #68225 21st Apr 2011 6:47pm
