![]() | Home > Puma (Tdci) > Filling coolant |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Yes, there is a bleed screw and a bleed procedure in the WSM.
It's not over complicated at all but it is in the manual which you really need. It was a couple of years ago so won't give you guesstimate details as I can't quite remember what was involved. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
cornishbob Member Since: 04 Jul 2016 Location: cornwall Posts: 11 ![]() ![]() ![]() |
Pardon my stupidity wsm?
I take it it’s some sort of service manual? Cheers 2008 90 csw |
Work Shop Manual - WSM.
![]() I may have some pages of it printed out somewhere I will take a look for late this evening for you. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Hi appreciate that if you can I just found an old post on here that explains it,
Says about revving it to 3grand for a minute and idle for 5 and so on Does that sound right? Cheers 2008 90 csw |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
I struggled to get it to bleed using WSM procedure, could not get the engine hot enough. Had to take it for a drive and keep pulling over to check the level. 2007 110 TDCi Station Wagon XS
Cornishbob - Yes, that's right. Do you still want me to see if I can find the pages?
Bluest - Same here, I done the WSM proceedure to the best I could. Then drive it as normal and keep a close eye on the fluid level so sorted then in next to no time. Trying to get up to temp this time of year won't work being cold unless driven, so I would recommend doing the WSM method. Then driving and checking. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Hi no need if it’s same procedure as I found I’ll just try that, thanks for your help folks 2008 90 csw
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
the workshop manual procedure is just to get it hot enough to have the thermostat open. Sticking a bit of carpet over the front grill will help too as the fan sucks cold air through the rad as the viscous fans never fully disengage.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Same here ![]() ![]() ![]() |
