![]() | Home > Technical > Are front and rear wheel bearings the same? |
YES
front and rear wheel bearing stc4382 two pre side hub seal FTC4785 stack nut RFD 100000 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8341 ![]() ![]() ![]() |
Yes they are Cheers
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4296 ![]() ![]() ![]() |
Thanks both! 2007 110 TDCi Station Wagon XS
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5331 ![]() ![]() |
https://www.ebay.co.uk/itm/Land-Rover-Disc...SwENhZdxQB
these are the boys to go for ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Yes agree with above use timken bearings if you want them to last.
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Just out of interest, is this a roadside repair? I ask because I have seen advice to carry a spare bearing set when off road travelling but my Haynes manual
It's for a spare kit in case it goes in Morocco. Whether I can do it without a press, I don't know. 2007 110 TDCi Station Wagon XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17877 ![]() ![]() ![]() |
You do not need a press or vice and it can be done easily at the roadside provided that you have the right tools.
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
The right tools consist of:
- 19mm socket to undo drive flange bolts - something to remove the circlip - flat screwdriver to knock back lock tab - hammer - 52mm socket - soft bar for removing and reseating bearing races - grease All you really need. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Thanks for the info, a few more things for the spares box! 2010 Defender 110 Station Wagon, Santorini Black.
All assuming you use the double nut method not the single stake nut method. Torque can be done by feel pretty easily. Ed
What’s that then? 2007 110 TDCi Station Wagon XS
Referring to double nut vs single? Older models have two nuts with washer that's peened over to lock the two nuts in place.
Setting the torque, do it up tight (one grunt) until you feel resistance when spinning the wheel and then back off the first but so that the hub spins freely again. The lock tab and do up second nut tight against the first. I find it easiest to loosely do up the second but first before bending the lock tab over the first. Then you can tighten the second and lock it in place. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Thanks What’s the process on a standard Puma? 2007 110 TDCi Station Wagon XS
