Home > For Sale & Wanted > [Wanted] 90tdi rear tub.
Scott R
England 1985 Defender 90 Other HT Nato Green
Has anyone got a 90 rear tub for sale? Must be from a tdi with the fuel filler near the front, a td5 one is no good to me. Reasonable condition as I accept it will have dents/scrapes and corrosion.
The closer to Northamptonshire the better
Post #680296 20th Jan 2018 11:54pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I have one its not a good one, But could be repaired will send some pictures
Post #680354 21st Jan 2018 11:18am
Scott R
What sort of damage has it got, as long as it’s reasonably straight down the sides I’ll be interested. I will be cutting 4inches off the rear so if there’s damage on the rear corners then that’s not a problem.
Post #680386 21st Jan 2018 12:57pm
foxyred
Rear passenger corner is damaged, will take some pictures rest is straight. capping knackered is off this
as you might be able to see its not too bad
Post #680413 21st Jan 2018 3:27pm
Scott R
What sort of money are you looking for?
Post #680466 21st Jan 2018 5:46pm
gilarion
You can use a TD5 rear tub as I had a similar problem when I rebuilt my project TDi and changed the rear tub to a TD5 one, so I installed a pipe to run from the TD5 back filler to the under seat tank. I got a stainless steel exhaust manufacturer to make up the pipe for me think at the time it cost somewhere in the region of 50.00 and works a treat.
You will also need a length of rubber tubing to extend the breather pipe all the original rubber hoses from filler neck and fuel tank are still used, though I bought new OEM ones.
It really is a simple job to fit once you have the stainless pipe and a few hose clips. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #680492 21st Jan 2018 7:01pm
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
I've got one, but I think it has holes right at the back where a roll cage was once fitted. Reckon it had the front bulkhead trimmed as well for one of those "Mudstuff bulkhead removal kits".
It's parked up down the field at the moment, but can grab some photos if you're interested. It's off an early 90 pickup.
Post #680640 21st Jan 2018 11:46pm
Scott R
Best i dig a photo out and you'll see why i can't use a td5 tub.
Post #680858 22nd Jan 2018 9:27pm
Scott R
Holes near the back doesn't matter, as said I'll be cutting 4inches out at the rear and fitting a full cage. A trimmed bulkhead sounds interesting also as I have thought about doing that.
Post #680862 22nd Jan 2018 9:31pm
foxyred
How's £50 ?
Post #680875 22nd Jan 2018 9:49pm
Scott R
PM sent.
Post #681156 23rd Jan 2018 9:17pm
foxyred
will ring tomorrow
Post #681502 24th Jan 2018 10:52pm
