Home > In Car Electronics > Dash speakers and switched power
JonJop
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Hi all
Just purchased my first defender and am sorting out the audio install.
The standard under dash speakers are 4” but hoping to get 5” in.
I’ve noticed mud sell 5” spacers. Has anyone used these? If so do you have any pics? If not, has anyone managed to get 5” speakers in?
Also, I need a switched power lead to connect to my amp/sub combo. Are there any easy, obvious ones to connect to near the inner fuse box?
It’s a 1996 Defender 90 300Tdi.
Thanks in advance.
Post #681009 23rd Jan 2018 10:48am
barbel jim
5" fit in a TD5 band TDCI without spacers so i'm pretty sure they'd fit in a TDI Thumbs Up Not too sure why you want a switched live. as usually your switch live comes from the headunit, quite often labeled a a remote/Aux ? with the main power feed taken off the battery ???
Post #681252 24th Jan 2018 9:07am
JonJop
Thanks mate - I’ll whip the 4” speakers out and see what space I have behind. I can but some 5” spacers but wasn’t sure if the dash would still need cutting or not.
The switched live is to power the amp. I know there is one on the headunit but on my old t4 there was a male switched live (blade type) in the fuse box which was handy as could simply connect a female blade straight to it. Wondered if there was anything kicking around the defender fuse box that would do the same thing rather than have the wires going up to the headunit itself.
Post #681253 24th Jan 2018 9:11am
grafty99
You may struggle without spacers if the 5 inch speakers are deeper. The wiper motor is quite close to the speaker cut out on a Tdi Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #681258 24th Jan 2018 9:47am
JonJop
More than happy to use spacers, was just wondering if the magnets will fit in the space without having to cut the dash. I guess it depends on the speaker really though.
Post #681264 24th Jan 2018 10:21am
barbel jim
I've fitted focal k2 powers to both a TD5 and puma. From memory there about 68 mm deep!? No spacers needed. Iirc in a TD5 fuse 33 is for heated seats and blank. I'm sure a poke around with a multimeter will soon find you one
Post #681272 24th Jan 2018 10:59am
bankz5152
I used the spacers and did not like the look or fit at all. So I cut the dash out to suit the 5" speakers, looks miles better.
Post #681289 24th Jan 2018 11:51am
Mountain_man
Wales
You would definitely need a spacer on the passenger side to clear the wiper motor on a tdi. On the drivers side you may get away without depending on the shape of the speaker. At worst you may need to enlarge the hole, but there is plenty of depth behind for the magnet so no worries there. I made my own spacer for the passenger side using a jigsaw and some mdf. Just sprayed it black to suit. Looks fine. I also fitted tweeters into the top of the dash and these have really made a big difference to sound quality.
Not sure now, by I may actually have fitted 6" speakers Smile
Post #681290 24th Jan 2018 11:52am
JonJop
Thanks guys.
I’ve fitted 17cm Morels in the real and have some 13cm Morel components that’s I’d like to get in the front. Will take the current 10cm speakers out and see what’s needed. I’d be happy using a spacer if it means getting them in and will then have a think about the best options for tweeter placement too.
I did wonder about a heated seat supply being available so I will check that out.
It’s a powered Alpine sub that I’m fitting too. The whole install is from my VW T4 and is an awesome set up so want to use as much of it as possible in the Defender.
Post #681299 24th Jan 2018 12:27pm
barbel jim
Fitted
You can see from this picture how I enlarged the original 4" hole to take the 5" Thumbs Up
Post #681347 24th Jan 2018 3:18pm
JonJop
Awesome - looks straight forward enough to me!
Will be able to get this sorted I'm sure.
Post #681348 24th Jan 2018 3:20pm
JonJop
How did you cut the top of the dash to fit the tweeters and where did you fit the crossovers?
Post #681349 24th Jan 2018 3:20pm
L110CDL
Off Topic ^^^ are they Cosworth recaro's fitted Whistle Clayton.
Keeper.
Post #681510 24th Jan 2018 11:18pm
barbel jim
To mount the tweeters up there you just need a hole saw. The top dash comes off. but if your careful you can drill insitu. The top is a hard foam on a steel frame. Thumbs Up
Post #681655 25th Jan 2018 8:34pm
JonJop
Install done - went with blam front components - sounding awesome
Post #682247 28th Jan 2018 11:09am
