Home > In Car Electronics > Sub / amp wiring route
Djcla
Hi
I'm pretty clear how you wire up an amp / active sub but say it's mounted on back of cubby box, how do you route wire to battery and best place to get ground from?
Post #680563 21st Jan 2018 9:43pm
mk1collector
If you don't have heated seats there's a rubber bung in the top of the battery box you could go through. So down from the amp and under the seat next to the seat runner then into the battery box. Ray
My build thread
Post #680569 21st Jan 2018 9:47pm
Djcla
Ah I have heated seats Sad
Post #680589 21st Jan 2018 10:23pm
barbel jim
There is more than 1. You could always drill a new hole a fit a rubber grommet
Post #680625 21st Jan 2018 11:23pm
Djcla
I'll take a look and report back cheers
Post #680635 21st Jan 2018 11:37pm
mk1collector
You could just make a bigger hole in the rubber grommet. Ray
My build thread
Post #680646 21st Jan 2018 11:53pm
Minch90
I made a bigger hole and shoved the wire through, then along the funny lip where the bulkhead was. I put the wire into some coiled plastic protective covering, used a seat runner bolt for my earth. The input cables from the head unit under the carpet and along that lip thing. All works well, v loud (1200W Juice sub box), nice!
Post #680871 22nd Jan 2018 9:44pm
