Home > Td5 > Flippin’ water leak
Page 2 of 2 <12
Balvaig
Also check the seam on the roof between the sloping front and flat rear part. This is prone to leak. Also the mastic in the gutters can crack and leak. Both fairly straightforward fixes.
Post #680600 21st Jan 2018 10:46pm
barbel jim
Mine was the join of the roof and windscreen frame by the gutter. Depending if you parked uphill or down, would alter the appearance of leak to the rear.. it only needs the tinyest of holes Big Cry Dug out the old and pumped full of Sikaflex (my preferred silicon Wink ) leak sorted Thumbs Up
Post #680623 21st Jan 2018 11:20pm
lightning
Yes could be that as well, will re seal it.
Post #681116 23rd Jan 2018 6:55pm
Page 2 of 2 <12
