Home > Technical > td5 not holding boost
razz
2001 Defender 90 Td5 PU Caledonian Blue
hello everyone , while i remember , during yesterdays whizz about , i noticed the boost , does go up to 1.35 on my nanocom , but then tails off to a low reading , i have a very long uphill section of a bypass near me , and with the fitted special track tyres , she`ll pull 70 and thats it , was just wondering why it does not hold boost , if its leaking , which side would be coursing the drop ? my foot was buried in the boards for well over a mile , yet once its gets up there , fairly sharpish , the boost goes drops away
Post #680544 21st Jan 2018 9:12pm
grafty99
Might be worth removing and cleaning the map sensor Thumbs Up
But it could be a pipe or the intercooler. No strange noises is presume? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #680546 21st Jan 2018 9:14pm
bankz5152
Any black smoke?
Actuator move freely?
Post #680548 21st Jan 2018 9:21pm
razz
cor , you lot are fast , no strange noises cos the tyres n straight thru pipe are loud enough , its got a new big intercooler , fancy pipes etc , i`ll change the map sensor , as i have a spare , the one in is clean , a thought , could the turbo not have enough puff with the bigger intercooler i wonder
Post #680553 21st Jan 2018 9:26pm
razz
bankz5152 wrote:
Any black smoke?
no smoke , new actuator , found the old one seized solid at the weekend , hence why my nanocom was plugged in to test n set up
Post #680554 21st Jan 2018 9:27pm
grafty99
New intercooler and pipes would be my fist port of call then. Anything that has changed from before should be the first thing to check. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #680566 21st Jan 2018 9:45pm
grafty99
Also if you are running a boost limit box that could have gone faulty. But definately check what's changed first Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #680567 21st Jan 2018 9:47pm
bankz5152
Yeah what boost your running? 18psi is the limit. Any above needs a boost box or uprated MAP sensor + raised boost limit
Post #680586 21st Jan 2018 10:20pm
barbel jim
Leaky new silicon pipes would be my guess. Checked they've not slipped and the clips are tight tight. Then intercooler Thumbs Up
Post #680626 21st Jan 2018 11:26pm
razz
Hello everyone , i’ve Checked the pipes , but will carry on tests after the weekends pay/play day . The boost is around 19psi by google . Ady
Post #681404 24th Jan 2018 7:15pm
grafty99
Standard boost on a Td5 is 1 Bar (~15psi) 19psi is right at the upper limit of what the ECU will allow before boost cut strategy kicks in. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #681406 24th Jan 2018 7:22pm
