Home > My Defender > Introducing Buggsy my 110 TD5
Page 5 of 12 <123 456 ... 101112>
Procta
mash, i recon this has been a ticking time bomb and its just let go, after you have had a bit of a fiddle with it. But at least you do have a spare engine now anyway to rebuild or for parts. Can you not just drop a 300 TDI in there? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #679097 17th Jan 2018 1:47am
grafty99
Just a thought actually Mash. It hasn't hydrolocked on diesel has it? Might be worth popping out the injectors Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #679139 17th Jan 2018 8:58am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Hadn’t thought of that grafty will have a look when I get a chance, I’ve managed to bag a complete engine with full service history for £500 so hopefully I can fit that next weekend.
Procta I would need to do a fair bit of graft to fit a 300tdi, I did choose the Td5 for a little bit of refinement on the longer drives Rolling with laughter
Still loads to do whilst I wait for the engine, just a pain pushing it in and out Rolling Eyes 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #679235 17th Jan 2018 1:57pm
Procta
i know how you feel mash, I was sold a dud engine years ago for my vvc metro project, Engine ran a ok, but as soon as things started to warm up properly. Bear this in mind the car never even moved off the drive. The engine started to scream and the engine bay was full of water! Powered that off very quickly, fired it up and it sounded like it was like a diesel. When we removed a few things we found out that the head had been off and idiot had chewed a engine bolt to the point where you couldn't get that out, and then they had damaged the vvc pick up cam, Which was about 500 quid to replace! So that engine was scrap straight away! me and my dad were proper Censored off, as we had just got the car back together. The lads on the forum at the time who were following the project, really did feel for us too. Wasn't fun pulling it all back and dropping another lump again. Really did kill the fun of doing the project that did, and in the end I wanted to just get the thing on the road and get some enjoyment out of it.
If its hydrolocked on fuel, could it be easier fix? By letting it dry out after the injectors are removed. Has it been remapped or anything like that? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #679246 17th Jan 2018 2:23pm
grafty99
By the amount of white smoke in the pictures I would be surprised if it hadn't hydrolocked on fuel Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #679252 17th Jan 2018 2:34pm
Mash
Finally managed to get some investigating done today, took out each injector (bar one as the cam position wouldn’t let me remove it completely) at a time and tried to rotate the engine, no luck.
Looking down the timing chain I can see my crank moving but nothing else, as I’m going to at some point be pulling it all apart I decided to mark the cam and cam sprocket, loosen off the 3 bolts and test, now I have full movement to here so it appears my cam has seized Shocked 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #679694 18th Jan 2018 7:49pm
Procta
Censored hell! Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #679802 19th Jan 2018 1:32am
Mash
Ok so what to do with Buggsy?
Engine broke ? Yes, yes it is. New one on route ? Yes............. ok prep for removal.
So this weekend consisted of removing all looms, pipes, nuts, bolts and anything else I could see holding the engine in, well that didn’t take too long so I was able to start on a few other things.
First thing on the list was fit the new door seals to see if I could reduce the water ingress into the vehicle, drivers door went great, then onto the rear door, I removed the old seal and notice the roof and the correct panel didn’t line up very well:
A little while later and I had it looking like this:
With that much better I moved onto the lip the seal sits on and started to strained out bits like this:
All seals fitted so will now see how dry it is tomorrow.
With the seals sorted I thought I would make a start on removing 15 years of grime from the seatbox and rear bulkhead, I had some spare fatmat so decided I might as well make a start on the sound proofing:
I have do a few other small bits but forgot the pics Embarassed so will update later on Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #680549 21st Jan 2018 9:23pm
L110CDL
Looking good after your touch there Mash Thumbs Up i think that the weather for tomorrow is the best day off the week for dryness Wink Clayton.
Keeper.
Post #680636 21st Jan 2018 11:37pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
HK07
Blimey Mash, I want to get on with my project, but it's too bloody cold.
I'm working on bits and pieces inside the house.
Credit to you out there freezing your ball joints off on project number three!!!
Roll on some warmer weather!!! 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #680644 21st Jan 2018 11:51pm
Procta
its those little jobs that to the trick, Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #680665 22nd Jan 2018 6:53am
Mash
Cheers guys Thumbs Up I do fortunately have use of a workshop out of hours ( as long as I have fixed enough kit that day) Whistle 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #680721 22nd Jan 2018 1:51pm
Mash
I’ve not had much time on Buggsy this week but have been doing a few bits, I continued with the cleaning out of grime from the seatbox / battery tray and fitted more soundproofing;
Moving on to the door retaining brackets, after looking at the cost of replacements I decided to clean up mine and refit them;
A lot of corrosion on the brackets from the various leaks that have been left for so long, some time with a wire wheel and a coat of red-oxide later;
And finally a coat of satin black;
After the rust converter has done its job I thought I would add a little paint over the top and add another layer to the footwell, unfortunately I only had black paint but as it will all be covered by matting and insulation it’s not a big problem;
Finally today I refitted the seats and started to add the factory seatbox cover;
Hopefully tomorrow I will have my engine chains back so I can pull the dead engine and make a start on cleaning the chassis and external foot wells in preparation for dinitrol. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #681999 26th Jan 2018 11:29pm
grafty99
Looking good Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #682004 27th Jan 2018 12:20am
L110CDL
Getting there Mash Thumbs Up Clayton.
Keeper.
Post #682472 28th Jan 2018 10:17pm
