Home > Maintenance & Modifications > Best LED light bar and rear lights.
TOP5N
Hi, i'm looking to buy an LED light bar and led rear spot lights for my 2015 defender... What is the best quality brand to get that wont fog up / leak etc... not after the cheapest, i'm after the best.
Regards,
Chris
Post #680472 21st Jan 2018 6:08pm
bankz5152
Lazer.
Post #680473 21st Jan 2018 6:13pm
Devon-Rover
Lazer Lamps Seconded
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #680474 21st Jan 2018 6:21pm
TOP5N
They look like great quality lights, but ideally i am after around a 52" light bar to go above the windscreen on gutter mounts
Post #680477 21st Jan 2018 6:30pm
leeds
After the best?
Lazer Lamp or Vision X
Now to be road legal optional driving lights have to carry an APPROVAL mark. Note APPROVAL mark NOT Emark
Chances of cheap LED bars being approved for road use is minimal.
Brendan
Post #680479 21st Jan 2018 6:33pm
leeds
The chance of finding one that will be road legal is next to nothing.
We have a Vision X mounted on our green 110, not road legal!
A good 52" light bar is TOO bright for most uses. Too much reflection from road signs, tree trunks etc. OK if you are going into big wide open deserts. Switch the lightbar off and onto good bright main beam headlamps and you will be driving 'blind' for a few seconds as your eyes adapt to large change of light level.
I would advise smaller ones which can be switched on indidually or in pairs so you can alter the light level.
Brendan
Post #680482 21st Jan 2018 6:42pm
TOP5N
I will be having a separate switch in the cab, as the light will mainly be used for work purposes, to light up my work space... so looking for a full 52" that wont be connected in any way to my driving lights for road use. Thanks for the replies
Post #680484 21st Jan 2018 6:49pm
sako243
Rigid Industries? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #680488 21st Jan 2018 6:56pm
defender_uk
is there a way to fit them, especially rear working lights. without having to drill the body? I really don't want to go down the roof rack route if i can 'elp it. 2020 First Ed 110.
replaced by 2021 250 110 Commercial
Defender_uk
Post #680509 21st Jan 2018 8:13pm
Devon-Rover
OK then a triple r 28 is near as dammit 52 inches wide. light that one up and you'll bring down UFO's with the beam
https://www.lazerlamps.com/home/lights/triple-r/triple-r-28-std Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #680510 21st Jan 2018 8:14pm
sako243
Gutter clamp? Ed
Post #680512 21st Jan 2018 8:18pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Rigid industries now have an E approved line, and I must say the performance and quality is awesome Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #680525 21st Jan 2018 8:46pm
Likeomg
Lazer rs8 in a bar, triple R on the rack
Whistle
I also have the Lazer utility 80 rear which i have in a box still to fit... Neutral
Post #680685 22nd Jan 2018 11:13am
TOP5N
Lovely looking truck there.
Post #680689 22nd Jan 2018 11:26am
Likeomg
I can confirm the triple r is a bit overkill for the majority of Driving, but it is lovely when your out in the sticks... like daylight Driving
The rs8 is road legal I believe and have on my high beam stalk... it’s probably more than enough but I just like the look of the big bar hence having it...
Been on maybe 9 months 0 water ingress
Post #680733 22nd Jan 2018 2:45pm
