![]() | Home > My Defender > Corrosion paranoia |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Need to do mine as well, hoping for a day that is at least a bit warmer. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 688 ![]() ![]() ![]() |
What is the foam you are using? Think I need some!
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1771 ![]() ![]() |
It is the pro-kleen snow foam with wax. I have it in a selection of flavours but don't get banana - it smells like monkey puke
![]() I use a hot water pressure washer too which I think helps it foam. ![]() |
The rear X member on the Puma is getting a bit scabby. The v8 is tucked up in bed, I even put the heater on for her today.
Ah bless! But then again it might soon be worth £150k
I don't think I've washed mine for about three months now
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Come on Ray - do tell. Watchdog?
Crime stoppers
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I last washed mine March 2017. It stinks like a farmyard inside. There are cleaner tanks out on the Plain today. I think it needs fumigating more than cleaning ![]() |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
That's why I got a DCPU - muddy dogs & anything that stinks go in the back!
I think that was a wise decision!
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 886 ![]() ![]() ![]() |
"I last washed mine March 2017"
I'm not quite as bad as that, but my truck hasn't been cleaned since I let my local Albanians loose with their pressure washers as its Christmas present. Of course, my neglect shows in the truck's corrosion, I reckon the windscreen hinges and window catches which have turned chalky white will need replacing in about fifteen years' time, and the rear X-member is showing a few bubbles so will require a bit of fettling by the normal 10-year mark, i.e. 2021. In the meantime, I just keep on keeping on, sometimes I really wish I had the time to wash and polish my toys... nah, not really! Peter |
