Home > Off Topic > email nightmare with iOS
discomog
I currently have an iPad and iPhone, both operating on iOS11.2.2. I have recently opened an email account on the iPad and it works perfectly. I have tried to enter the same email account on my iPhone using exactly the same parameters but it keeps telling me that there is a problem with the incoming IMAP server.
Do any of you IT wizzkids have any idea why I've succeeded with the iPad but not the iPhone? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #679829 19th Jan 2018 9:52am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I remember having a similar issue - I'm no expert, but I seem to remember I changed one from IMAP to POP3 or something... I think it was something to do with needing one as the 'master' & one as 'slave', i.e. only one could delete the email from the server (the IMAP one), so on the other (POP3), you can read & delete but it's still available for the master to download.
That's a little vague & shaky info tho - hopefully someone who actually knows can answer!
Post #679843 19th Jan 2018 10:29am
hafman
Is it an iCloud email account? If so, IIRC you need to get an app specific password, rather than use your "standard" iCloud password.
https://appleid.apple.com/#!&page=signin
Post #679844 19th Jan 2018 10:34am
Chugga90
Mine did this, none of the updates which followed fixed it, what seemed like years on an Apple chat session did not solve it.
On an off chance I tried my internet/email provider.
They said make sure the SSL is set to off in settings.
This solved it and has worked for two weeks since doing that!
Post #679887 19th Jan 2018 2:09pm
discomog
Chugga, I thought you may have solved my problem but alas SSL is already switched off. Thanks anyway. Defender 90XS SW
Morgan Plus 8
Post #679933 19th Jan 2018 4:39pm
Chugga90
That’s a shame.
Good luck I know how annoying it is.
Post #679939 19th Jan 2018 5:03pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Not sure why it would be different between the two but what sort of account is it, which supplier ?
It may be that there's a maximum concurrent login, make sure your iPad is turned off to make sure the two aren't competing with each other.
When you added the account, which account type did you choose ? Sometimes, if you know the details it's easier to use the "other" option rather than one of the templates.
Assuming you are using an iMAP account, go into the advanced settings on the account and make sure that the incoming settings are the same as your iPad, port number, path prefix, and SSL status as well as the authentication type. http://www.yorkshireoffroadclub.net/
Post #679955 19th Jan 2018 6:10pm
discomog
Davew. I'll try switching the iPad off. I am using the "other" option. I will try all that you suggest and let you know if I solve it. Defender 90XS SW
Morgan Plus 8
Post #679958 19th Jan 2018 6:19pm
