Home > Maintenance & Modifications > Dashboard mods
dantastic
Dashboard mods
I'm about to take my entire dash out to fit an AirCon and I was thinking about other mods and things I could do at the same time. I'm also going to install a reverse camera monitor on the dash down by the gear sticks so I was wondering what cool mods people have done to their dashes, and if there are any other jobs I should do whilst having the dash out.
Post #679263 17th Jan 2018 3:19pm
drinkdrinkdrop
Off the top of my head, a couple of bits worth doing with the dash removed are adding a second washer jet and swapping the wiper relay for the VW type that gives intermittent wipers, i've also added a common earth for various accessory switches, usb ports etc so it's often worth adding a multicore wire or bunch of wires from the battery box into the dash area so you can add future switches without having to remove the entire dash.
Post #679273 17th Jan 2018 3:53pm
grafty99
Extra sound barriers to reduce some engine noise Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #679275 17th Jan 2018 3:58pm
rallysteve
Depends a little on the model and age but i would definitely remove and at least clean/grease the wiper mechanism or better still replace the spindles and rack. 02' 110 TD5 Double Cab Rebuild Thread
Post #679280 17th Jan 2018 4:22pm
bluebottle
Add another 12v socket.
X-eng column lock.
Route wiring or condition for later installation of Bluetooth mic for head unit or switches for work lights at rear etc...
Post #679518 18th Jan 2018 12:13am
dantastic
All great ideas!
I have new window washers already somewhere in the shed, didn't think about that so they will be installed.
Some Dynamat won't go astray either.
Running some cable for later use is also a great idea!
Post #679560 18th Jan 2018 10:41am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Whilst the dash is out, it's well worth going over the outside with a hosepipe and see if there are any minor leaks coming in.
As for the extra cables, if you have the space then run a length of conduit down from behind the radio to the transmission tunnel, it makes it much easier to poke cables through if you want to add more at a later date. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #679567 18th Jan 2018 11:07am
bankz5152
Soundproofing!! Most the noise in a fender comes from the bulkhead
Post #679569 18th Jan 2018 11:18am
Screbble
As already stated - wiper mechanism (refurb of replacement) and conduit and or spare loom for future mods.
Best of luck Thumbs Up
Post #680248 20th Jan 2018 8:15pm
