![]() | Home > Technical > Will P38 front radius arms fit onto Defender? |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 927
No.
Unless you consider a major re-engineering project to relocate the chassis mounting side of things to match them. I would forecast that bump clearances are gonna make things tricky. the P38 chassis is quite different too. |
| MEJ999 Member Since: 25 Sep 2014 Location: Peebles Posts: 7
Thanks, I assumed that it would not be simple as everybody would do it if it was.
| All times are GMT |
