![]() | Home > Puma (Tdci) > Fluid loss ? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
Check if it is oil (clear= gearbox, less clear=engine) or diesel. Sometimes an overfilled gearbox spits oil through the upper breather.
Fuel pipes run through the left side of the chassis and go over the Tbox. Puma 110" SW ............................................................. Earth first. Other planets later |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
just had lr assist out , needs to go into dealer, transfer box oil seal failed
