Home > Maintenance & Modifications > Rijidij wheel carrier
ericvv
I read on Aulro that this carrier is similar to the Kaymar I use, equally strong and seemingly pretty similar design and installation too, but with the added advantage over the Kaymar that it opens together with the door in one move.
Does anybody on here in Europe have a Rijidij single wheel carrier installed?
Probably a rhetorical question, but are you happy with it? Any drawbacks at all? (unlikely)
Any distributors know in Europe? Nothing is sure yet, but thinking about possibly replacing my Kaymar by a Rijidij carrier.
Below is a website link and a picture.
Eric
http://rijidijoffroad.bounce.com.au/#/defender/4551247239
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #678069 13th Jan 2018 6:04am
Pickles
Another VERY well known Aussie.
Check out his website & see the work that goes into these carriers,...He makes a heap of stuff including a range of bullbars.
His wheel carrier would be one of the most well engineered ones I've seen.
Pickles.
Post #678071 13th Jan 2018 6:45am
familymad
Not sure I would want to cut the rear tub of mine 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #678076 13th Jan 2018 7:47am
ericvv
You just cut a few cm of the narrow metal strip separating the rear tub from the rear crossmember, and which has no structural function.(see detail below) You certainly don’t cut into the tub itself. That is similar as with my Kaymar. Those two Aussie carriers are stronger than anything else, no wobbling or other. Rijidij probably the best of the two, that’s why I’m thinking about it.
Eric
Post #678078 13th Jan 2018 8:34am
Devon-Rover
I must admit for future planning I like the look of the carrier / jerry holder
Post #678155 13th Jan 2018 3:56pm
filcar
Australia 2012 Defender 90 Puma 2.2 SW Fuji White
I have the jerry can spare wheel combination on the rear of my Puma 90. Rock solid and will probably outlive the vehicle. I was really keen to get the spare off the door and the jerry cans are a cheaper solution to the small fuel tank on the 90. Sill tanks were going to cost upwards of $1200 each.
Post #678564 15th Jan 2018 3:40am
Timo K
Finland
I have a twin spare carrier from rijidij also, super happy with it, amazing quality. I would recommend it. It's identical to the spare + jerry can combo structurally.
Post #678573 15th Jan 2018 7:25am
agentmulder
Kuwait
Looking at these at the moment, wondering if any of the single hinge options (Safari Equip, Nakatanenga, etc.) have a hi-lift jack mount as standard or option?
Aus based might be helpful considering I'm in NZ Thumbs Up Solved the bowel problem, working on the consonants...
Post #678577 15th Jan 2018 8:15am
leeds
Neither the Nakatanenga or Safari Equip single point wheel carriers have an option for mounting a high lift jack.
However you can get a mount for spare wheel. In AUSTRALIA
Brendan
Post #678614 15th Jan 2018 10:11am
