![]() | Home > In Car Electronics > Mobile Phone Holder for 300Tdi |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I think there is a company called aukey who make stick on magnets that stick on the back of your phone or case
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Just found it. You could use the stick on bit for your new case and the holder in another vehicle maybe?
AUKEY HD-C5 Car Phone Holder Air Vent Magnetic Phone Mount for iPhone 7 / 6S / 6 / 5s / 5 , Samsung Note 8 / S8 , Nexus and Other Android , Windows Smartphones - Black https://www.amazon.co.uk/dp/B00HSAE808/ref...wAbHXD0VD6 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 774 ![]() ![]() ![]() |
Thanks chaps but that is similar to what I have already mounted on the top right of the MUD Console.
The problem is that my new phone case is a book style jobby so it needs a clamp type holder so that the front flap is held behind the phone. I think if I can get the fin for the Tektrax holder off of the top right hand corner a RAM-B-347 should fit there. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Definitely a vote for the RAM mount X-Grip. by far and away the best phone/device mount i have ever used. I bought the kit that included the suction mount and intended not to use this but hard mount instead. Not going to do that anymore as that suction mount is flipping' fantastic... Sits perfectly above the dash and even fits the nanocom as well ![]() ![]() Photo if you want it. |
A Photo to see how it looks with the suction mount would be good if you don't mind.
I assume it grips better than the garmin one then? My sat nav only needs the sun on it for a couple of minutes and its in the footwell again. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 408 ![]() ![]() ![]() |
I've got Brodit mounts in both my 300tdi's, they're adjustable up/ down and left/ right and don't move at all when tightened up. They're modular so you buy the bracket for your vehicle, the bracket for your phone and fit them together.
https://www.brodit.co.uk/?gclid=EAIaIQobCh...gJCnPD_BwE |
I've always liked the look of the Brodit system alas they do not make a holder for my phone and looking at the generic holders that they make not sure whether they would work with the case I have on my phone.
Next time I change phone I may have to go more mainstream so that I can get an otterbox type case which may help with the mounting situation but for now I have the Wileyfox Swift 2X and it will be staying for at least 18months so I need a solution that will work with it. It looks like the best plan at the moment is the RAM Mount x grip. The only remaining question is whether to use a screw on base on the corner of the mud console or a windscreen mount. I am sceptical of suckers on the windscreen as all the ones I have had for other things (Satnav x 3 and dashcam) have always fallen off at random inopportune moments. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Phil, the smallest base is probably the diamond base plate.
Have a look here Base size measurements 2.5" x 1.25". It looks like it might fit either side of your sat nav or on top of the mud console. Other possible places include 1) Fuse box cover close to one of the bolts 2) Through the edge of shelf to left and below steering wheel 3) Side/top of Mud tray 4) If you have a cubby box through the front facing slope. We had a radio fitted there once on a diamond base. If going through plastic use some large repair/penny washers 20/25 mm diameter. Time to get tape measure out or make a cardboard template and see what suitable fixing places you can find. HTH Brendan |
Brendan,
Thanks for your suggestions.. took me a while to work out where you saw the sat nav.. it is in fact the screen for the reversing camera. The Sat Nav is (or probably was I haven't looked yet today) suction mounted on the windscreen. Ideally I would like the phone to sit as near as possible to where it used to which is where the round silver and gold dot with the rubber spider is on the top right corner of the MUD console. I fear that with the screw/bolt on mounts that in that location I could not fit big penny washers. Would a backing plate with corresponding holes to the mount and as big as possible so that it sandwiches the plastic be good enough? Possibly with the 4 hole base 2" x 1.7" as that would fit quite neatly on that corner. Regards Phil 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Phil, a backing plate would be fine. Does not have to be a precision engineered work of art.
How necessary is one? Who knows? I would just err on the side of caution and fit something to spread the forces etc. Brendan |
As promised; Excuse the empty Mud Dash it will be filled in with gauges shortly...
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I will be buying a second one shortly for the passenger side... many pointed comments for the wife about why does she not have a cool mount for her phone... ![]() ![]() ![]() |
Please be careful about where you place items on the windscreen. Ram Mounts used to have a very useful page on what could be fixed where in regard to the windscreen. Can not readily find it now.
![]() C & U regulations, highway code etc comments on obstruction of forward vision through windscreen by stickers/sat nav/ air fresheners etc. From MOT Testers section 8.3
Now IIRC anything above 40mm higher then the normal parking position of the drivers windscreen wiper is a NO NO. Have seen drivers sticking their sat nav bang in the middle of the zone A of the windscreen wipers which would be a major obstruction of forward vision. In the event of a collision then it would be ![]() Just be careful o the positioning of those phones and sat navs. Brendan |
Thanks for the pics geobloke.
Brendan, I didn't realise there were actually rules laid down but having seen the photo's above I do not want mine anywhere near that high up. My old system used to stick up about an inch over the top of the dash and didn't impinge on the windscreen view at all. My Sat Nav is as low as I can get it in the middle of the screen and the dash cam is about as tight in behind the rear view mirror as possible. When placing these bits I have tried to maintain all the useable viewing area off the windscreen, however, the sat nav does obscure part of my bonnet so I'll have to keep an eye out for low flying things ![]() Wide Track Sankey- In bits- Gone to a new home M0XQS |
Hi Brendan. I have just had to run out to Miffy to check how high the mount is, I was pretty sure it did not obscure any vision of the road...
From eye height; ![]() Click image to enlarge Could be lowered a tad, but is well inside of the area masked by the bonnet. Trouble is there is not a great deal of room on the Defender dash for satnavs and parking cameras etc. Definitely below 40mm above the parked position of the wipers. Actually the position of that boost gauge, albeit temporary, is a terrible place to put anything... |
