Home > In Car Electronics > Headlight polarity reversal for LED
boode
England 2003 Defender 90 Td5 HT Rutland Red
Just tried to upgrade to a nice new pair of LEDs but no light output Sad
Checked polarity of wires in headlight plug and they are reversed so a negative current flowing for main or dipped beam
I previously upgraded the headlight loom to an IPF loom that allows high output bulbs to be used (fitted by a garage)
This loom has three relays that the wires run through - and looks very complicated
Any one have a diagram of the IPF loom or any ideas how to modify it to reverse the polarity in the plugs ?
The RedWhite wire from the headlight plug that should be the ground wire - goes to a 30amp fuse then onto the chassis - it does not go to the relays
I am very confused
Post #677553 10th Jan 2018 10:28pm
grafty99
I could pop over and have a look with you if you like? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #677555 10th Jan 2018 10:33pm
boode
Thanks George - that would be a great help
I will PM you for a convenient time
Post #677556 10th Jan 2018 10:36pm
