Home > Technical > BAS intercooler and silicon hoses - first drive
familymad
Finally had my first drive in the 130 today after doing the following
1) Removal of water separator in airbox - have not cut out the restrictor yet....
2) BAS intercooler
3) BAS silicon hoses - Both fitted with airbox in situ
4) Nugget intake kit
So here are my impressions. It pulls cleaner from idle to 2000rpm. No hesitations. Smoother in stop start traffic with jerky stuttering totally gone. M25 today at 7am confirmed this clear improvement! Slightly quicker throttle response but doesn't feel faster at all. And, it makes a noise like Darth Vader gurgling on mouth wash on some throttle openings - window closed can't hear much difference.
What I haven't managed to do (see also 'find') is where the last silicon hose is meant to go and how to change it! It's the smallest little elbow and no one appears to have talked about fitting that one on this forum? Some decide it's too much work.
Any hints and tips? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #676962 8th Jan 2018 8:52pm
jst
std or remaped?
thanks for posting Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #676981 8th Jan 2018 9:23pm
familymad
Totally standard. The re map on the cards for this year before morocco. Mind you, quite fancy the full uprated VGT turbo now !! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #676986 8th Jan 2018 9:36pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Good to hear as I have the parts on order. Razz
Post #676990 8th Jan 2018 9:41pm
JOW240725
Sounds great! You wait until you get the remap!! Quite nice doing it in stages so you can see/feel the difference.
VGT is on my shopping list Confused James
Instagram @suffolk_rovers
Post #676993 8th Jan 2018 9:49pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Familymad
The small elbow goes from the bottom of the turbo onto the end of the steel pipe feeding the intercooler on the RH side of the engine. It’s a pain to do, I ended up seeking advice from Pete Bell to get it done. His advice included remove top of fan cowl, release tension on the belt, unbolt water pump (don’t disconnect any hoses), and push it back, this will give you some space to gain access to the turbo hose. The new silicone hose was an ultra tight fit and took a serious amount of hot water, soap, jiggling and swearing to make it fit!!
Hopefully yours will be a bit easier than the full day I spent tearing my hands to pieces Thumbs Up
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #677038 8th Jan 2018 10:53pm
TutC
Australia 2013 Defender 110 Puma 2.2 SW Corris Grey
Totally agree with John, it's a pig to get on. Some blokes say you don't have to move the water pump, but I found the same as John that loosening the water pump gives you that little bit of extra space to get the hose in. It's only one more bolt to remove after taking out the two bolts that hold the steel connecting tube in position. Be prepared to loose some bark off your hands and don't have the kids anywhere near because you will be cursing a lot. Rolling Eyes
Post #677076 8th Jan 2018 11:42pm
agentmulder
Kuwait
You'll loooove the remap Thumbs Up Thumbs Up Thumbs Up Thumbs Up Solved the bowel problem, working on the consonants...
Post #677107 9th Jan 2018 6:52am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Interested in your intercooler/hose mod and even more interested to hear what the addition of the remap will in due course bring.
I see you have the Nugget intake modification.
That and a free flow exhaust make noticeable difference to how the motor revs and responds to throttle. I have their large diameter aluminium RAI with the intake mod, and have no silencers in my custom made side exit exhaust (vehicle isn´t any louder than before, cat is still fitted) and am impressed how sporty the throttle response is.
Concerning the lower elbow. in my view it has to be worth doing as that particular hose does split after a while. I wasn´t aware of the problem until on a UK trip we suddenly experienced loss of power accompanied by a whooshing sound when pressing the throttle.
I soon concluded it was a hose, but looked all over the engine bay and couldn´t identify where it was coming from. The upper two intercooler hoses were intact. It was Sunday evening, so i posted in the forum and immediately got helpful advice and was informed that a specialist workshop (Keith Gott) was nearby. We stayed in a hotel and arrived there Monday morning. As their workshop was fully booked, their parts manager stepped up and offered to do the job. i watched and was fascinated how many parts he had to remove to get to the hose. It is on the nearside (LHS) of the motor and extremely tight. He acheived the job within about 45 mins, but knew what he was doing.
If I remember rightly, my 2.2 had 65000 km and was four years old when the hose went.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #677109 9th Jan 2018 7:20am
Wild Card 90
Here you go!
http://www.defender2.net/forum/topic46890.html 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #677110 9th Jan 2018 7:28am
familymad
That sounds like a job for March or April. I have a history of immobilising my Landies just when the snow starts!!! Big Cry
The hose next to the airbox was a real fight and having air con didn't help. The viscous fan just wouldn't budge off so access was a pig overall. Copious amounts of hot water and washing up liquid are indeed your friend.
Will post some pics of the hose that went on ours. It had been sliced by the alternator I believe. Just nicked it and then she blew. Happened 60 miles after getting off the ferry from 2000mile Pyrenees trip. Would have been a mare to fail in some of the spots we ended up Crying or Very sad 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #677117 9th Jan 2018 8:32am
tookaphotoof
Had a split turbo hose followed by the inter cooler hose on my previous 130 when the garage drove the car back to me. That’s the main reason I ordered the silicon hoses.
Post #677119 9th Jan 2018 8:57am
familymad
Worried that silicon or not, it could do this again.... hoping that the damage was done pre alternator strap modification. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #677124 9th Jan 2018 9:38am
tookaphotoof
And because I’ve been too busy with work and some personal issues I had the pleasure today to experience the same as with my other 130. Hissing noise combined with lack of power followed by an error.
Managed to stop at a petrol station to pop the hood. Found the crack in the in the intercooler hose.
Bought some ductape in the shop and carefully drove the car home.
Now... How on earth people manage to install the silicon hoses is beyond me! 🤬
Post #709848 29th May 2018 10:05pm
NickMc
Get coolant on the belt and it’ll squeak and do your nut in, better to remove it Thumbs Up
Post #709861 29th May 2018 10:40pm
