![]() | Home > Td5 > Temprature |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I removed my fan about 3 years ago, maybe longer and have never had a problem, even towing my parents 110 on a tri axle transporter ![]() Much less risky than actually blocking the radiator as there is still air moment ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
Before removing the fan try to stop if with idling engine - with proper working viscous clutch in the fan, it is possible with one finger. ... I recommend use someone others finger for first test. Or a piece of cardboard. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
My TD5's always taken around 5 miles to warm up and the temperature drops rapidly at tickover. It's the 'norm' with that engine.
Maybe that's why the XS model has a heated screen and seats..... ![]() ![]() |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
On my puma the fan engages so infrequently and is so loud when it does the first few times it happened (before I’d understood what it was)I thought I’d broken something! 2014 Keswick Utility 2.2
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3256 ![]() ![]() |
I have to say l have never had the heater go cold in my TD5 110 when stuck in traffic in cold weather.
Low-Range Member Since: 30 Sep 2016 Location: BC Posts: 41 ![]() ![]() |
Before I put in an electric fan had to replace viscous fan. My vehicle definitely heated up when viscous fan failed. I replaced the 2.5 N/A with a 300tdi and went for electric, as it came with the Turner Kit. If its winter that's causing the cool down a rad muff is the answer, plus a hotter thermostat.
annette Member Since: 24 Nov 2017 Location: Tilarán, Costa Rica Posts: 68 ![]() ![]() |
Yes I fully agree with low range.
When I had my 109 v8 I used the same solution. here we recommend electric fans to avoid overheating. Viscous fans seem to pack up when it is over 50º in the sun ![]() |
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 ![]() ![]() |
Remove fan??? What??? How???
Not here in Kenya... a dead fan cost me a new head... With OEM borg Warner viscous I now barely get above 73C on normal running, can barely get it to high 90C on hard runs. Monitor temps and other readings via MDMAN EMS. |
OlavLRD110 Member Since: 03 Sep 2015 Location: Tallinn Posts: 20 ![]() ![]() ![]() |
Fan removed 3 years ago.In summer temp max85..88C (installed Omron temp controller) even in traffic jam.
In winter warmed up faster. For winter Webasto and Defa Warm Up. TD5 coolingsystem is owersaised. |
I go off-road and even with a good working visc. fan I managed to get it in the red zone a few times. With full throttle spinning 35"Simexes the heat builds up. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
