Home > Maintenance & Modifications > Securing adjustable tow hitch
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
I have the dixon-bate type adjustable tow hitch on the back of my 110.
However, it has always worried me that all someone has to do to steal my trailer (even with hitch lock), is to remove the 'r' clip and pin from the spreader plate, and bob's your uncle...
Anyone got any tips for preventing the pin removal, or other scurity measures?
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #67681 17th Apr 2011 5:37pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Post #67691 17th Apr 2011 6:40pm
Fifth Horseman
http://www.dixonbate.co.uk/towing/product.asp?PartNo=202018
Is the official (but expensive) solution - I'm sure mine was a lot cheaper when I got it. If you go with this, don't leave the plastic cap that it comes with on all the time as water will build up over time and cause the locking mechanism to rust - I caught mine just in time.
You could try drilling a standard pin to take a padlock (either as well as or instead of the R clip, depending on the amount of metal at the end of the pin), so the pin can't be removed with the padlock in place.
Post #67692 17th Apr 2011 6:43pm
Zagato
Dito, many put a padlock through - ultimately not very effective but will stop someone short term.
Post #67697 17th Apr 2011 7:15pm
szracer
Thanks, Chaps.
I had thought of the padlock solution, but since it has to be a pretty thin padlock, I guess (as Zagato says) it's only a visual deterrent.
Expensive as it is, think I will have to stump for the D-B solution - Still a lot cheaper than a trailer! Rolling Eyes
2005 Ducati ST3
1954 Sunbeam S8
Post #67744 18th Apr 2011 9:05am
mse
Do what my made does - stonking big chain around the A of the trailer/caravan etc to the bar of the tow bar (the bit you can easily remove) Mike
Post #67829 18th Apr 2011 6:23pm
leeds
I use a small nut and bolt to 'secure' pin.
On red 110 a chain/cable goes through the A frame and through a welded on recovery loop
HTH
Brendan
Post #67913 19th Apr 2011 2:09am
Large motorbike chain from the frame of the DB hitch, to the A frame (or a welded on "ring") of the trailer.
Post #67927 19th Apr 2011 8:16am
I had one of the proper (and very expensive) DB locking pins for a while on my discovery, and to be blunt, it wasn't worth the money. The lock is nothing like durable enough for the position it ends up in, and in a short space of time it corroded so badly it became useless (and I always kept it as clean as possible by cable-tying a length of bicycle tyre inner-tube over it to keep the muck out.
After the lock broke I made a replacement which used a locking wheel-nut to secure the pin, which worked a lot better and was far more durable, however in the end I simply went down the big-chain-and-padlock route since most of the trailers I tow are ring-and-pin hitch anyway, and there's no point really securing the slider to the car if the trailer can still be unhitched.
So for me as well it is the big chain and marine grade stainless steel padlock round the A-frame of the trailer and round the tow bar frame. I suppose someone could still steal the slider and leave the trailer, but it hasn't happened yet.
Post #67933 19th Apr 2011 9:37am
