|  | Home > Maintenance & Modifications > Double speed indicator |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804      | Could be corrosion in the bulb holder or a connection issue, probably rear indicator? 2002 90 Td5 Station Wagon
 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  6th Jan 2018 9:42pm |
| Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245      | Thanks, will give it a good clean tomo. | ||
|  6th Jan 2018 9:43pm |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347      | I think it's normal for indicators to flash double speed if a bulb fails etc. - or it used to be.
 As indicated by Grafty, if the bulb is tested and known as good, I'd give the connections a really good clean and get a multi meter or similar on the wiring. Sometimes the connection in the bulb holder needs a bit of 'adjustment.' Sometimes bulbs (or 'lamps' as I am continually reminded) can fail at the base and show no visible signs at the element. Worth having a few spares anyway, or better still, get some LED's as they are only cheap for a pair of complete 'original' looking lights - RDX, Wipac on eBay. Hope you get it sorted  | ||
|  7th Jan 2018 9:10am |
| Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461      | Remember to check the side indicators on the front wings too? | ||
|  7th Jan 2018 12:54pm |
| Posting Rules
