Home > Technical > R380 tdi gearbox
peterl
1987 Defender 90 300 Tdi HT Epsom Green
R380 tdi gearbox
Is this box the same for a tdi and V8 or are there marked differences,
Wanting to replace a 300tdi with V8 and keep box, is this possible
Post #676510 6th Jan 2018 11:31pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
My understanding is the 5 th gear is higher for a V8.
The Ashcroft transmission site will probably have the info you need.
Post #676513 6th Jan 2018 11:40pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Bell housing and input shaft are different. Ashcroft did have some stubby r380s for sale a while ago. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #676517 6th Jan 2018 11:47pm
Retroanaconda
Yes you’ll need to have the gearbox input shaft swapped for a V8 one (spigot bush diameter is different) or modified to suit.
Bellhousing bolt pattern means new bellhousing as above.
Your best bet would be to find a Discovery V8 R380 and swap your Defender remote housing over with the adaptor that Ashcrofts now do. Or if having it rebuilt get a Defender selector rail put in instead.
Post #676558 7th Jan 2018 11:32am
