![]() | Home > Puma (Tdci) > New 110 - clonk on stopping engine and whine on no-load ? |
| austen Member Since: 11 Mar 2008 Location: Sydney Posts: 52
My TDCi has now done 15K and there is no whine. But my previous TD5 whined at around 100-110kph when coming off the throttle. It sounded like the rear diff but the dealer assured me it was the transfer gears. These were replaced under warranty and the whine went.
However, I get a rattly clonking noise when starting or stopping the TDCi. Not there if the clutch pedal is depressed. I will raise it with the dealer next service. Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
No nothing with mine.
austen i had the same clonking noise with mine took to dealer ,new flywheel clutch and release bearing sounds like your release bearing bud NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY Last edited by fekete on 31st Jan 2009 8:02pm. Edited 1 time in total |
| slocum Member Since: 16 Oct 2008 Location: Italy Posts: 19 |
Pob, the whining comes from the rear diff. I'll have to replace mine next week for the same problem.
It occurs in many Td4. |
| Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119
Thanks for the replies, how long will it last as it is? I can not take it back to the dealer for a month or maybe two months - will it matter? What's the worse that can happen?
I've done almost 15000 Kilometers in this conditions. The noise is there since the car was new. Is getting louder, but since now I had no problems.
Spoke to dealer (who is brilliant) and they have suggested I see how it beds in with some mileage and if it's an issue they will sort it out - on that note I am happy. I will see if it lessens
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
mine has been doing it since about 6000miles (now on 14000). LR say it is nomal but I think it is not normal.
I get the opinion that as long as it's logged with the dealer then it's going to be covered if it goes pop. My whine is not deafening or anything it's just there. I am happy to run with it and see. I have 2 years warranty left so plenty of time to see if it gets worse.
| felos Member Since: 24 Nov 2008 Location: Athens Posts: 12
The noise you hear when you turn on or off the engine is the springs of the clutch disc falling apart,I΄ve just changed mine with a new ....improved type as LR says. NOT A TRANSIT
