Home > Maintenance & Modifications > Relay Mounting
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Relay Mounting
Hi All,
Having had headlamp problems I have ordered and received new column switches and a Boomslanger wiring loom.
This is the relay block :
Any tips on how to mount this to the vehicle, I assumed there would be some sort of mounting bracket to take a screw? As there isn’t would cable-tying it to a suitable object/part in the engine bay be ok?
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #675663 4th Jan 2018 11:55am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I'd ask them if they could provide mounting brackets (or maybe you could buy them separately somewhere?)
https://www.autosparks.co.uk/standard-12-v...20amp.html
Other solutions would have been housings or relays with integrated brackets:
https://www.autosparks.co.uk/relay-housing...relay.html
https://www.autosparks.co.uk/standard-12-volt-relay-30-amp.html
Not sure if cable ties provide enough "grip" to hold the relays under vibration.
Post #675676 4th Jan 2018 12:35pm
ChrisCM
Thanks for the links Macfrank.
I would have thought that the relay holders/connection blocks would have had a mounting system of some sort, the relays themselves have got mounting slots for the bent metal type holder but this can’t be the way to mount these as any vibrations would tend to loosen the relatively heavy connection block. I’ll have a look and see what I can find on the interweb. 2010 Defender 110 Station Wagon, Santorini Black.
Post #675680 4th Jan 2018 12:49pm
Ian825
England 2006 Defender 90 Td5 HT Zambezi Silver
l bought same loom a little while ago, same then they didn't supply a mounting bracket, it wasn't hard to make one up but thought it a little cheapskate! might be worth anyone ordering one going forward they ask for one at tine of order up front as it doesnt appear to be a one off!
Post #675684 4th Jan 2018 1:38pm
Why not just un-pin the connections, replace connector blocks for vertical surface mount ones?
Easier than making tabs, and can allow you to remove Relay with mount in situ rather than having a trailing socket.
This is why I like Durite, I like the mounting tabs present and they have flying sockets inc.
Your other option would be replace the Relays with new ones with mounting tabs. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #675685 4th Jan 2018 1:44pm
ChrisCM
Spoke to Paddocks, they say no one has ever asked about this before! They are contacting the manufacturers to find out what they recommend.
In the meantime, I’ve had a rummage around my “spares” box and come across a small Schneider 65 x 65 x 35mm ip55 electrical box, this fits the relays + bases perfectly so if nothing better turns up I’ll give it a try.
I don’t really want to start breaking down the loom, rather defeats the object of buying it in the first place, they’ve sold enough of these over the years so it can’t be an insoluble problem. 2010 Defender 110 Station Wagon, Santorini Black.
Post #675687 4th Jan 2018 2:01pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've got quite a few of the small metal relay mountings laying around,
If you want some, pm me your address and I will send some to you FOC
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #675689 4th Jan 2018 2:22pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
I fitted a boomslang loom a few weeks ago and found the same problem.
Luckily I had a spare relay holder bracket lying around.
Fitted mine in behind the nearside headlamp and ran the loom across the front behind the grill.
Then used the alternator for supply. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #675692 4th Jan 2018 2:44pm
ChrisCM
Ian series 1, PM sent. 2010 Defender 110 Station Wagon, Santorini Black.
Post #675693 4th Jan 2018 2:51pm
ChrisCM
Hi Baz,
I was thinking of going back to the battery, is there any advantage to using the alternator other than ease of cable run? 2010 Defender 110 Station Wagon, Santorini Black.
Post #675694 4th Jan 2018 2:53pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Me too on the mounting bracket. Currently using the Power steering fluid bracket. It is one of those meaning to get round to jobs of finding bracket that slides into the slots on the connectors. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #675699 4th Jan 2018 3:13pm
gilarion
Get these relay holders from eBay, and then just make up a retaining bracket out of a piece of scrap metal to fix them too or just bolt them somewhere in the engine bay. £2.60 for five.
https://www.ebay.co.uk/itm/5-Pcs-5mm-Hole-...SwICpaO-wn
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #675726 4th Jan 2018 4:16pm
It has always annoyed me that despite literally years of searching I have never been able to find an after-market supplier of preformed metal strip mounting brackets for these relays, by which I mean strips like those welded in the seatbox of the Puma with a row of tabs on them.
Some years ago I managed to buy a 5-relay bracket which I believe was a Classic RR part, but given that it is a simple thing to make I don't know why no-one seems to make such a thing. Landrover must buy the stampings from somewhere to spot-weld into the seatboxes, but they don't have a separate part number.
Frustrating, and perhaps an opportunity for an enterprising entrepreneur.
I don't like the individual brackets because they are a hassle if you want a row, and look un-original.
Post #675727 4th Jan 2018 4:18pm
ChrisCM
Hi Gilarion,
Problem (I see) with these is that the Boomslang kit comes with rather chunky relay holders/connection blocks so using this type of holder means that the relay blades are carrying the weight/stress of the holders/connectors and wiring. If wiring without the Boomslang kit and connecting direct to the relays then they would be ideal. 2010 Defender 110 Station Wagon, Santorini Black.
Post #675736 4th Jan 2018 4:34pm
gilarion
Totally agree I have spent hours over the years searching for multiple relay holders. These are the closest I have come and are from an old Volvo.
Post #675744 4th Jan 2018 4:45pm
