![]() | Home > Technical > Webasto |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
It's called a dosing pump, each pulse delivers a certain amount of fuel and the Webasto decides how much it needs. So 1 pulse per application sounds right. Just need to see if it is actually delivering fuel. 2002 90 Td5 Station Wagon
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
It does not pulse when turned on, only if connected to a external supply
So either the wire is broken or the controller is not sending any pulses of power to the pump Are there any other causes for no power to the pump |
Yeah you're right, it is likely to be a wiring fault or controller fault. Have you tried removing power from the Webasto for a couple of minutes in case it's locked out due to flame failure? 2002 90 Td5 Station Wagon
I will try taking fuses out
But we have a power cut at present so I will try tomorrow |
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
So Today I managed to get the Webasto to fire up twice
Pimp pulsing fine - Hot exhaust smoke being produced Then after a minute it shuts down - no pumping, no fire Just expels exhaust for a further 30 seconds and turns off |
Flame failure detected most likely. I think it uses the glow plug as a flame detector once it's ignited. It could be that the glow plug is on the way out. Needs plugging into a webasto diagnostic tool really
Any local Webasto specialists ?
I could try Devon 4x4 but they are not specialists |
Not that I know of, I think D44 are registered installers though so should have the diagnostic kit
Is it worth phoning a local commercial HGV repair company? They could put you in touch with an expert on "night heaters"
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
Sounds just like the one in the wagon at work, I had it all to bits and give it a good clean out and it’s never missed a beat since. NO ROAD..........EXCEPT FOR LANDROVER
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106 ![]() ![]() ![]() |
Had similar issue with the one in our motorhome when in Bavaria a couple of winters ago, went to local Bosch centre they cleaned inside and quick service. Runs better now than when fitted new by English dealer. The Germans reckoned the burner was not set up right when fitted and it had sooted up.
Thanks for all the replies
I did nothing to it today and it started fine and I left it running for an hour with no issues ???? I will get it serviced and cleaned - a local motor home centre is just about to become an agent - but they will have no experience |
Just because it's a new agency doesn't necessarily mean that the fitter hasn't got a wealth of prior experience
