Home > Technical > Unknown Vibration
mini Anaconda
Unknown Vibration
Chaps,
I seem to have picked up a vibration from underneath my 90 (200tdi). I can feel the vibration through the floor while driving, but it is not there all the time - maybe only occurs 2 or 3 times in a 10 mile journey.
It doesn't seem speed dependent as it occurs at 5mph or 30mph. I have checked the propshaft/UJs which seem fine, has anyone got any ideas what it could be?
Many thanks Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #675097 2nd Jan 2018 9:21am
jst
Did you take props off to check them for play?
is it engine speed related? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675101 2nd Jan 2018 9:45am
mini Anaconda
I don't think it is engine speed related as it occurred when I was coasting at 5mph and also when driving at 30.
I didn't take the props off, only looked for play as attached to the vehicle. BORG - Bucks & Oxon 4x4 Response Group
Post #675102 2nd Jan 2018 10:01am
agentmulder
Kuwait
^Just to make sure we're on the same page.
He means engine speed (RPM), not vehicle speed... Solved the bowel problem, working on the consonants...
Post #675106 2nd Jan 2018 10:55am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Vidrations on a Defender can be a nightmare to diagnose.
Wheels out of ballance.Usualy happens at certain speeds,above 40mph.
Wheel bearings,could be this,as you can feel it at all speeds.Check by jacking each wheel up & gripping tyre at 12 & 6.then 9 & 3,and shake the wheel.
If there is movement at 9 & 3,but not 12 & 6,then this points to swivel bearings.
U/J's as JST said you need to take them off to check properly.
Loose wheel???? Probably not,but I have seen it before.
Marc.
Post #675122 2nd Jan 2018 12:29pm
jst
Thumbs Up Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675124 2nd Jan 2018 12:37pm
mini Anaconda
Yes, 5mph was at idle and no rev counter on a Tdi for 30mph but not idle!
And thanks Sharkey/JST - I'll check soon and post an update.
Thank you Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #675135 2nd Jan 2018 1:23pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I had a vibration under my 90 Td many years ago at slow speed or coasting to a halt, turned out that the handbrake was binding. Stripped and cleaned it out and was all good after.
Could be worth a look. 2005 Td5 90 XS
Steve
Post #675252 2nd Jan 2018 9:55pm
jst
Handbrake tends to snatch at those speeds, 5mph. ESP after a run when its hotter. Not sure I have had vibration from it.
Ujs unlikely at 5mph. In fact will give it some thought as not sure at such low speeds. Other than wheel nuts as ^^^^^ Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675311 3rd Jan 2018 7:54am
mini Anaconda
Finally got round to having a look at this.
I changed the engine mount at the weekend and the vibration seems to have gone away. Very Happy Very Happy I can only assume it was sending a vibration down the chassis that I could feel through my feet.
Post #680859 22nd Jan 2018 9:27pm
