Home > In Car Electronics > Speaker upgrade in TD5
Page 2 of 3 <123>
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
My 6.5" Focals are mounted on the door cards with stand-off rings to accommodate the speaker depth, with the tweeters up high so as not to be obscured by your leg. The crossovers live behind the disconnected OE speakers in the td5 aircon dash extension. The JL Audio amp is in the driver's seat box and drives the Focals, with the Alpine head powering the rear speakers (currently a pair of Celestion SR Compacts until I get around to making something with another set of Focals to fit better behind the Double Cab rear seats).
It's not lacking bass but I'd like to add an under cubby sub in the future to give it an extra octave.
Post #674545 30th Dec 2017 11:22pm
bankz5152
Id be worried about them getting rather wet!
Post #674582 31st Dec 2017 1:07am
barbel jim
Djcla wrote:
Was looking at these below to save hassle, did you flush mount yours?
http://www.mudstuff.co.uk/products/in-car-...allow.html
There are spacers currently so I can live with the knees thing, not sure the ones above are angled though like the originals
They would do the job, although you'd probably find cheaper on the bay, halfrauds probably stock them too. I'd doubt you'd get angled like the originals. All my installs have been flush mount. Personal preference Thumbs Up
Post #674615 31st Dec 2017 10:41am
Djcla
Cheers , I see mudstuff do some rear corner speaker panels that look good too.. I'll make a shopping list next month and keep you all updated. They also do a neat sub that fits under the cubby box in the middle Smile.
http://www.mudstuff.co.uk/mud-sub-locker-953.html
http://www.mudstuff.co.uk/mud-rear-speaker-panel.html
Post #674677 31st Dec 2017 2:21pm
Djcla
Looking at these speakers from JL audio as they give me flexibility on how I install them. Any ideas if there is enough room to hide the crossovers behind the speakers some where?
https://www.caraudiocentre.co.uk/product_m...-33118.htm
Post #674771 31st Dec 2017 7:13pm
barbel jim
There is room Thumbs Up the focal power crossovers are massive and I got them to fit. You'll be fine Thumbs Up
Post #674814 31st Dec 2017 9:32pm
Djcla
barbel jim wrote:
You can remove the end cap easily on passenger side. Drivers I did insitu. I used the new grill cover to position and mark the new hole size, small molegrips can hold it in place and marked with a sharpie pen. I have used a dremel to cut the extra out, and also stitched drilled along the new line. It's all pretty easy, just measure twice cut once. If you look in my gallery there's photos of the td5 and puma. There a few threads, look in the definitive ice section from thread. More than happy to talk through it Thumbs Up
Ps is yours a puma or TD5 as the puma I used a fein cutter as only plastic
Edging towards this flush mount method, I've made a few card template of speakers size and 116mm for the hole to get an idea. Did you cut the leather type dash material or stitch drill it along with the metal?
Post #675065 1st Jan 2018 10:43pm
barbel jim
You don't Thumbs Up push them up towards the screen and trim the excess. It will allow you more depth. Pm me your number if you'd like to talk about it more Thumbs Up
Post #675071 1st Jan 2018 10:59pm
barbel jim
I'll try and remember to take a photo tomorrow for you Thumbs Up it's worth it
Post #675076 1st Jan 2018 11:19pm
Djcla
Photo be good thanks, I'm not quite ready yet to do the work just trying to plan the job and get my head around the work needed. Photo be great thanks as not sure what you mean by push up towards screen above.
Post #675085 1st Jan 2018 11:58pm
barbel jim
Might make more sense now Thumbs Up you can see the old footprint of the standard speaker and 2 fixing holes. But the hole has been cut for the new 5.25" speaker. In this case the orientation is across to the left, however it works better moving then up towards the windscreen, allowing maximum clearance from the bulkhead
Post #675113 2nd Jan 2018 11:37am
barbel jim
And fitted Mr. Green
Post #675116 2nd Jan 2018 11:47am
barbel jim
And tweeters flush mount Thumbs Up
Post #675117 2nd Jan 2018 11:51am
Djcla
thanks, what ill do is stick my templates on the dash and see how things look and post up some pics. As you say measure lots and cut once.
Post #675121 2nd Jan 2018 12:25pm
Djcla
its like a rabbit hole this as the speakers i found are too over powered and need an amp LOL.. Anyway ill decide on that later but a question for now is can you get adapters for the connectors on the LR speaker cables to save chopping them?
Post #675446 3rd Jan 2018 5:48pm
Page 2 of 3 <123>
