Home > Puma (Tdci) > Window gasket
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Window gasket
Hi, I've been looking at my window gasket i.e. the foam betwwen the window and bulhead and it seems to perioshing after 3 1/2 years!!! It sthis normal is there a remedy e.g. replace with better product. It also seems to letting water through!!!! 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
Post #67359 14th Apr 2011 8:36pm
110SEB
I'm interested to hear people's thoughts on this too.
Welcome to the forum, 110. Thumbs Up
Post #67385 14th Apr 2011 10:56pm
Happyoldgit
The windscreen to bulkhead seal is a very common source of leaks. Unless you want to raise the hardtop and separate the screen frame from the bulkhead one way of tackling the problem is to run a neat bead of good quality sealant along the join and as far inside as you can get once you've temporarily pulled the door seals away. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #67393 15th Apr 2011 6:43am
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Perhaps no more info than Miserableolgit has mentioned. You can buy a like for like replacement foam seal on eBay for around a fiver then it's just as above separate the hardtop/windscreen from bulkhead and replace seal! Apparently alot of work. I'd be keen to see if anyone has under took this as a DIY job with any tips. It's a job I wanted to do a while back but chickened out Rolling Eyes Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #67397 15th Apr 2011 7:24am
110
Are there better seal around? Is it just a case of losening the 4 bolts on each side near the door and rainsing the windscreen a few mil, pull out th eoriginal then insert the neww one? 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
Post #67403 15th Apr 2011 7:57am
Grockle
It certainly shouldn't degrade in that short time,is the screen tight on the seal ?,it's not an easy job to replace as you have to raise the roof at front to gain access to it,as previously mentioned.
good luck Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #67406 15th Apr 2011 8:10am
Happyoldgit
It's just a closed cell foam strip with adhesive tape on two sides - nothing special and available from lots of places (think trim and body supplies) either on a roll or by the length. I've replaced them on pre Puma Defenders before but would still run a bead of sealant around the joint new seal or not. Steve.
Post #67414 15th Apr 2011 10:21am
Grockle
you could try loosening the clamp bolts each side if the screen, get someone to sit on the front of the roof and retighten,this has been done by a guy on here and it stopped the leak. 2.4 90 XS
Post #67416 15th Apr 2011 11:51am
110
I think I'gg with the silicone route. Do you guys recommend any good BLACK silicone? I also nottinced that the lip that truns along the windows sill is a couple of mm up to the middle section. I.e it seems ity is made of 3 pieces and water may be coming through that way. 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
Post #67585 16th Apr 2011 3:30pm
